Emotiva XSP-1 preamp
Clipdat
Clipdat Posts: 13,095
I'm good on preamps currently, but I like the looks of this Emotiva preamp. I also like that it doesn't have a built in DAC. I wonder how this bad boy sounds?
Looking for thoughtful discussion on it's merits/specs and sound quality, please refrain from outright bashing of the Emotiva brand name.
xsp_rear_1500x.png?v=1516048196
Here's some specs/bullet points I found interesting:
"Exceptional sound quality via an all-analog, fully balanced, differential signal path with vanishingly low noise and distortion."
"Level control via a high resolution (.5dB/step) digitally controlled analog resistor network."
"Full analog bass management with independent, individually configurable, Linkwitz-Riley 12 dB/octave high-pass and low-pass filters for the mains and subs."
"2 sets of balanced inputs, 4 sets of unbalanced inputs, one set of balanced main outputs, and one set of unbalanced main outputs."
"Tight-tolerance surface mount components and short, precisely matched signal paths deliver a superb, tightly focused acoustic signature."
Unbalanced Input to Unbalanced Output:
S/N (signal-to-noise ratio, A-weighted, ref +6 dBV): > 113 dB.
Frequency response: 20 Hz to 20 kHz +/- 0.015 dB.
THD + N (harmonic distortion plus noise, @ 1 kHz): < 0.0006%.
IMD (intermodulation distortion, SMPTE method, 60 Hz/7 kHz): < 0.001%.
Crosstalk (measured at +6 dBF, 10 kHz): < 102 dB.
    edited February 2019
    I admit I giggled at "precision crafted" in China.
  • joecoulson
    joecoulson Posts: 4,943
    I can appreciate the tech but their components do nothing for me aesthetically. Even the back using those oversized plastic washers are fugly.
    Meh. Sorry just not feeling it.
  • I haven’t heard this preamp but
    I used their USP-1 pre and XPA1 Gen 2 monoblocks for several years. They sounded really good and never a single issue with it.
    I’d have no hesitation purchasing one.
    heiney9 Posts: 25,432
    Wouldn't touch it with a 10' pole.
  • steveinaz
    steveinaz Posts: 19,545
    Never heard any Emotiva gear, but the digital controlled volume is not a personal preference of mine. The build quality and styling look nice to me.
    tonyb Posts: 33,072
    It's what I would call another gateway piece into the world of separates for those moving off a receiver.
    Then people discover what we mean by "rabbit hole". :)
  • stangman67
    stangman67 Posts: 2,329
    Impossible to talk about how it sounds without actually hearing it. Specs mean next to nothing when it comes to sounds quality, you should know that by now
    mhardy6647 Posts: 35,017
    I have no opinion one way or t'other re: Emotiva.
    If one's philosophy runs towards more is more, this looks like an appropriate product.
    Sure has a lot of ICs in it.
    Not my cup of tea but some folks prefer complexity to gain flexibility.
    stangman67 wrote: »
    'specially, I'd opine, in a preamp.
  • SIHAB
    SIHAB Posts: 5,432
    I owned this unit at one time.
    As you can see, it is flexible. If you have Sources w/ XLR you can lower
    distortion a bit. (arguable, as you probably cannot hear the diff) The phono pre is good and you have a bit of control over things with the nice remote.
    On the other side of the coin, the xovers are hard to tune in exactly.
    I never was confident at the setting and tuning by ear.
    AFA sound, preamplifiers are tough IMO. The best for me don't do anything
    to the sound, yet somehow make it better. Ultimately, this didn't lift the
    boat enough for me to keep it. There is a somewhat rabid fan base and
    you would have no trouble moving it if it isn't your cup of tea.
    As an aside,
    If you like the looks its all there. I'm betting mods to this piece would
    bring it up to muster. FWIW
  • I have the XMC-1 and I love it. I have had it since 2015. I use a Parasound A31 to power my Lsim 703's and 704.
    nooshinjohn Posts: 25,926
    Personally, I don’t like having 40 blue lights staring me in the face. No need to have every button light up like that. To me, it makes it look cheap and detracts from not only the look of the product, but also the listening experience.
    It does, unfortunately, have something of that Pyle Pro look going.
    Mind you, I still like the blue LED thing (passe though it may be) but one would be plenty.
    Then again, de gustibus non est disputandum.
    stangman67 wrote: »
    I asked about it's specs and it's sound quality. Two disparate things.
  • Personally, I don’t like having 40 blue lights staring me in the face. No need to have every button light up like that. To me, it makes it look cheap and detracts from not only the look of the product, but also the listening experience.
    FYI, the lights on all the front panel buttons and the volume control can be dimmed in ten brightness levels. Level 1 is barely noticeable, if at all, except in a very dark room.
    McIntosh MA252 Integrated Amp, LUMIN D2 Network Music Player, Yamaha Aventage RX-A840 receiver, Emotiva XPA Gen3 2 channel amp, Polk LSiM 703 speakers. Oppo UDP-203 Blu-Ray player, Polk LSiM 705 speakers. Polk Signature S20 speakers.
  • gurot1
    gurot1 Posts: 519
    I had it in a home theatre setup. I am not that adept at sound quality stuff, so I won't comment on that...but it was nice having HT bypass. I have since simplified my setup after realizing that I won't get to sit down and just listen to music for quite a few years until the little ones grown up a bit. I did like that it has dual sub outs. I wish the lights could be turned off as it sat under my PJ screen. I did like the look of the preamp though
    lsim705,lsim706c,lsif/x(4)+mc80(atmos)
    rti6,csi5,fxi5
    mark090852 wrote: »
    that's a plus.
