Odyssey Audio Stratos Extreme amp - No longer available
ALL212
ALL212 Posts: 1,664
edited February 2019 in For Sale (FS) Classifieds
Odyssey Audio Stratos Extreme power amp for sale. Shipping from Rockford, IL or local pickup. $1000 + shipping and fees.
Chassis is solid but not perfectly clean.
This is the "Extreme" model but not the Kismet that you may have heard referenced. 180,000uf of capacitance and dual 400va power supplies for 800va total. Should provide 180 watts and run stable from 2 ohm through 8 ohms. She weights in at around 50 lbs - maybe more.
The balanced inputs will work but are not true balanced inputs, merely unbalanced wired for that connector.
odysseyaudio.com/products-stratos-stereo.html
The strange cover around the input and output cables provides additional shielding from RFI and EMI.
I use one of these in my main rig and have no plans of changing that. I just haven't run this one in some time and maybe someone else can use it.
Aaron
Enabler Extraordinaire
