Bluesound Node 2i
Looking at this streamer/DAC pretty hard. Anyone have any experience with it?
«13
  • stangman67
    stangman67 Posts: 2,329
    edited January 2019
    I have the Node 2 and love it, and ive heard the 2i is at least marginally better then it’s predecessor. Easy to use, great sound quality at an affordable price. Can’t go wrong
  • deronb1
    deronb1 Posts: 5,021
    Cool, thanks. Will it read a 2TB HDD (Fat 32) FLAC?
  • displayname
    displayname Posts: 1,204
    I've only personally seen it in limited demo environments, but all sources say that it is worth the upgrade vs getting the Node 2. I have heard that the Aries Mini is still the preferred solution for the price point, but the 2i is very close and a good alternative as the Aries Mini becomes harder to find.
    Analog: Hana ML > MoFi UltraDeck > Bob's Devices Sky 20-S > Sutherland 20/20 w/LPS
    MastersounD Dueventi > Rosso Fiorentino Certaldo or Hifiman EF600 > Hifiman Arya Stealth
    Discogs
  • stangman67
    Here is a good article on storage solutions. Invariably setting up a NAS is the recommended solution. I don’t use mine as a network player, as I pretty much exclusively use it for tidal streaming
  • stangman67
  • deronb1
    Great info! Thanks Stang! Seems like it will work as I will keep it plugged in all the time and the HDD has its own power supply.
  • Mikey081057
    Mikey081057 Posts: 7,127
    edited January 2019
    I have a node 2 and love it... Does everything I need it to do and they are constantly updating the UI and software. They listen and respond to their end user forum community The app also works with android which the Aries does not. If the 2i is improved then it is good.
    Post edited by Mikey081057 on
    Garage | Polk Monitor 5B's
  • deronb1
    Sure arent any deals on em!
  • displayname
    deronb1 wrote: »
    A used one posted today for $400. It was gone in hours.
    Discogs
  • deronb1
    deronb1 wrote: »
    Im sure it was
  • steveinaz
    steveinaz Posts: 19,545
    edited January 2019
    I'll be picking up one later this year. I'll use it "transport" mode with HDD attached.
  • deronb1
    steveinaz wrote: »
    Thats what I want to use it for as well
  • steveinaz
    edited January 2019
    If you get a Western digital with power supply, it'll power up/down automatically with the node---which is a neat feature. I use a WD "My Book" 2TB w/my Oppo.
  • deronb1
    Mine is a Rosewell? something like that. Has its own power supply.
  • Mikey081057
  • deronb1
    Thanks! Im gonna get one. Gotra pay Uncle Sam first tho...sigh.
  • steveinaz
    Cool. Let me know how you like the interface.
  • alucididea
    alucididea Posts: 113
    edited February 2019
    stangman67 wrote: »
    I’m about to pickup the new MDC BluOS 2i to use mainly for Tidal and MQA. How do you like the new BluOS 3.2? The last time I auditioned the interface was when version 2 was out. Are there much noticeable improvements?
    I didn’t stick with the old interface because I felt like I had to use the Tidal app to explore new music and then the BLuOS app to actually play. Is this your experience as well?
  • Mikey081057
    Here are some impressions for users who have actually heard them...
    https://forum.audiogon.com/discussions/how-much-would-i-lose-going-to-a-bluesound-node-2i
  • Joey_V
    Joey_V Posts: 8,600
    I use it. I believe it is good for the money.
    Run the coax out to the Emm Labs DAC2x.
  • Mikey081057
    Hans (not the guy from Die Hard) reviewed it
    https://www.youtube.com/watch?v=LIWkeXPjvyw
  • deronb1
    Node 2 arrived today. Nice sounding streamer. A lot of bang for the buck here. Reads my 2TB HDD just fine and have access to all files quickly. Using AQ Golden Gate ICs. Sounds better than dig coax, but havent tried toslink yet. Does a ton of things that ill probably never use, but nice to have available I guess. Now that the 2i is out these should be more available at deep discounts used. Grab one and ya wont be disappointed for the money.
  • steveinaz
    Just ordered mine yesterday.
    audioluvr Posts: 5,885
    So does this stream radio stations? Do you use your laptop or smart phone for display? Does it use bluetooth or wifi or both? Buddy of mine is interested in streaming from Pandora or Tidal but not sure how to do it cheaply.
  • deronb1
    The node 2 doesnt have Pandora. Not sure if the 2i does
  • deronb1 wrote: »
    BluOS does not support Pandora. (I’ve been using the MDC BluOS 2i for a few weeks.)
  • Mikey081057
    Bluesound will allow any Bluetooth enabled smartphone, tablet, or computer to stream music to a Bluesound Player. Now you can stream music from Pandora®, Sirius/XM®, Apple Music®, TDC Play®, and many more services to your Bluesound system. ... The use of other Bluetooth 4.0 adapters may not be fully supported by Bluesound.
    tonyb Posts: 33,068
    Any of you guys get this, please do a good review of this unit. I'm seriously considering one but need to know a few things first.
    If it will pull iTunes from a windows PC. Some reviews say it won't, others say it can.
    The App- gets good reviews, others say it stinks. What I need to know is...if you can search in any category, add and subtract to playlists easily, if it crashes constantly or freezes. Support of Napster ? Though I may move to Tidal if their library is deep enough. Q doesn't seem to be very deep in the library judging by the other thread.
    Reviews are fickle, as some don't specify if it's the older node 2 or 2i. It's my understanding the app has also improved from the node2.
  • Mikey081057
    The app is the same between all Bluesound players. The app is stable and prompts you to perform updates when needed. Wifi and internet connectivity is the weakest link and that is the same for all network players. The 2i has updated it's WiFi capabilities although I had no issues with the Node or the Node 2.
    I also recommend using it with Roon in order to simplify bringing all of your online music services and stored music libraries. Roon will also allow "like" devices to have a multiroom experience... Airplay syncs with Airplay... bluetooth devices with bluetooth etc...Roon is simply the best audio related software I have ever seen or used and makes it all simple after a brief but easy ramp up. Roon offers a 2 week free trial.
    Apparently there was an issue sharing itunes to Bluesound... It appears to have been resolved. I believe that the Node2i also supports Airplay2 reliably now although I never use it. I do have some Airplay devices that I have used on my network and since they are "like" devices they can be joined thru ROON
    https://support.bluos.net/hc/en-us/articles/360000199908-What-Music-Services-does-BluOS-Support-
    https://roonlabs.com/howroonworks.html
    tonyb Posts: 33,068
    Mikey,
    What do you mean by weakest link ? Wifi drop outs ? Never had a problem with drop outs from my Sonos so I dunno if we can say it's relative to all network players.
    If that's the case, being prone to drop outs, that would put it off the list for me.
