Pass Labs X0.2 still has issues....
nooshinjohnnooshinjohn Posts: 22,909
edited January 2019 in 2 Channel Audio
I have a new(to me) Pass Labs X1, that was just serviced and given a clean bill of health at the Lab just this past week. It was sent in because it had a loud and very audible "pop" between steps on the volume, and an audible "hiss" similar to what you would hear on a cassette tape back in the day. This hiss gets louder with each step up in volume and once an increment of 10 is achieved, the hiss steps back down again.
A large shift away from factory settings for DC offset were found and corrected, as well as a handful of capacitors found to be out of spec and replaced. The popping sound has been diminished by about 50 percent, but I find that the hissing noise is still there and very much a distraction to listening.
I sit 10 feet away from my speakers, and use Polk Audio SDA-SRS 1.2TL's, which have crossovers that have been recapped. The speakers are 91db sufficient. Driving them are my tube amplifiers. All connections to source components are made through XLR cables made by Audioquest.
My previous preamp was a Pass Labs X1, which exhibited none of the noise issues I have described. I do understand the pop sound is a function of the volume control and is a characteristic of it's design, and I am more than ok with that.
All functions of the pre work as intended and it sounds great otherwise. The only issue that really concerns me is that hissing sound. It is present regardless of source selected and can be heard some 20 feet away from the speaker even if nothing is playing. Is there something that can be done to reduce or eliminate this noise?
The Gear... Carver "Statement" Mono-blocks, TriangleArt Reference SE with Pass Labs Xono Phono Preamp, Walker Precision Motor Drive, ClearAudio Goldfinger Diamond v2 cartridge and Origin Conquerer Mk3c tonearm, Polk Audio "Signature" Reference Series 1.2TL with complete mods, Pass Labs X0.2 three chassis preamp, PS Audio PerfectWave DAC MkII, Krell Evolution 505 SACD Player, Pioneer Elite SC-LX701, Oppo UDP-205 4K Blu-ray player, Sony XBR70x850B 4k, Polk audio AB800 "in-wall" surrounds.
I swear by my life and my love of it that I will never live for the sake of another man, nor ask another man to live for mine.” .
“If it moves, tax it. If it keeps moving, regulate it. And if it stops moving, subsidize it.”
  • audioluvraudioluvr Posts: 2,725
    And swapping out the pre with another eliminated this?
    Cambridge Audio 851N Streamer/DAC
    Polk SDA 1C's modded
  • pitdogg2pitdogg2 Posts: 17,295
    Man i was hoping this would be a giant game changer for you John.
    Bummed
  • nooshinjohnnooshinjohn Posts: 22,909
    audioluvr wrote: »
    X1 and no noise at all. Swapping in the X0.2 and the noise is quite prevalent. All cables are the same. The only change was swapping the preamps. I have triple checked everything, swapped cables, disconnected the sda, everything I can think of. I think the troubles are within the volume control itself. I cannot fathom why they did not change it when it was there.
    On the plus side.... holy crap this thing produces the largest soundstage I have ever heard come from my speakers. Everything was great before but now it is on an entirely different level. I hope a solution can be found, because I would hate to be on the prowl for a different preamp.
    I am listening at low level right now and the nuance and micro detail is astonishing.
  • BlueFoxBlueFox Posts: 13,805
    Good luck with it. I wonder if they do a listen test, or just measure the specs. I'm still waiting to get my XP-22 back.
    Bud - Silicon Valley
    Lumin X1 file player
    Sony XA-5400ES SACD
    Pass XP-22 pre, X600.5 amps
    Magico S5 MKII Mcast Rose speakers, SPOD spikes
    Shunyata Triton v3/Typhon QR on preamp, Denali 2000 (2) on amps
    edited January 2019
    They did an amazing job, including all new packaging and boxes, cleaned the crap out of it inside and out. AMAZING service all the way around, just can't live with that hissing.
    They say it takes 48 hours to warm up and settle in. Maybe I am being too hard on things right now, but something tells me this is just the character of this unit. I can't imagine Nelson Pass would accept this noise coming from a flagship preamp.
    The detail this beast is capable of is astonishing. Bud... you had an XP30 before, correct? did you have a similar issue, or way it stone quiet? I might look to acquire an XP20 if I can't get this one sorted out.
    Post edited by nooshinjohn on
    I had an XP-20, and it was dead quiet. Plus it never broke. :)
    Sony XA-5400ES SACD
  • ClipdatClipdat Posts: 8,754
    Send it back, since it hasn't been serviced to your expectations.
    edited January 2019
    It costs money to do that. My gut just tells me that it may not like my tube amps, which is a very real possibility. What I need is a solid-state amp to test that hypothesis.
    Why does the preamp care if the amp it's outputting to is tube or SS?
    Might just be a bad fit for them is all. I don’t have all the knowledge, but I am thinking a gain mismatch.
    I'm getting my read on: https://www.passlabs.com/sites/default/files/x0.2_om.pdf
    Could it be some weird configuration issue or setting that has been overlooked? It does seem strange that Pass wouldn't give it a listening test before sending it back.
  • monepolkmonepolk Posts: 1,094
    Do you have another system that you can try the pre in?
    Maybe reposition it so its isolated to see if it's some weird RF thing.
  • tonybtonyb Posts: 32,488
    John,
    Your not the only one. I have a hiss too in the upper frequencies after changing things back to what they were. Only thing that changed was the addition of a new older amp, same cables same everything same way everything was hooked up.
    Had the amp looked at, it's fine. Changed tubes in the pre, fine, still there. Nothing is more aggravating in this hobby of ours than chasing down an errant sound that appears that wasn't there before. Nothing bothers me more, than an errant sound I can't locate from where it's coming from. So much so...that I'm ready to rip it all apart and start from scratch.
  • txcoastal1txcoastal1 Posts: 11,484
    Might just be a bad fit for them is all. I don’t have all the knowledge, but I am thinking a gain/impedance mismatch.
    This can very much be the cause. Do you have the specs on the amp?
    When I was speaking with Dan (Modwright) while pairing up a preamp with the Thresholds he asked for the specs. He tweaked the LS100 slightly to better match up the impedance pairing
    https://forum.audiogon.com/discussions/how-to-match-preamp-and-power-amp
    http://av2day.com/question/how-do-you-match-a-pre-amp-to-a-power-amp/
    and many more on the web
    Good point Ron, a very important point too because sometimes we lay all the blame on a certain piece without considering it's just a bad match-up impedance wise.
  • heiney9heiney9 Posts: 24,148
    Clipdat wrote: »
    Not all gear plays well together and tube amps can be a bit more touchy.
    John,
    Knowing the caliber of the "lab", I am more inclined to think it's a gear mismatch more than a bad pre. Have you called and talked to Desmond or anyone else at Pass to bend their ear about your issue? You know how willing and helpful they can be. They would know more than anyone here what the issue might be.
    It would be nice if someone close to test it on a SS amp just to see what shakes out.
    Good luck and I'm sure you know Pass will bend over backwards to help you.
    "Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass
    Pass Aleph 30 | EE Avant Pre | EE Mini Max Plus DAC | MIT Shotgun S3 | MIT Z P/C's | updated SDA 1C| SQ Box Touch/Welbourne Labs P/S- Tubes add soul!
    Maybe someone in the area can lend you a SS amp to test this theory.
  • dromundsdromunds Posts: 8,950
    I agree with Heiney, I'd call them and have an in-depth talk about your issue.
  • marvda1marvda1 Posts: 4,105
    edited January 2019
    input/output impedance need to match.
    Amplifiers: MasterSound Compact 845, Ayre v6xe, Consonance Cyber 800,Kinki Studio EX-M1
    Transport/Dac: L.K.S MH-DA004, Cayin Venus cd-100i, Musical Paradise mp-d2 mkI,
    Musical Paradise mp-d2 mkIII
    Speaker Cables: Organic Audio Organic Reference 2, Analysis Plus Black Mesh Oval 9,
    Cerious Technologies Graphene Extreme
    Interconnects: Argento Organic Reference 2, Argento Organic 2, Gabriel Gold Reckoning
    Power Cables by: Cullen Cables, 6sons Audio, Swiss Cables
  • mhardy6647mhardy6647 Posts: 26,299
    edited January 2019
    The ol' rule of thumb (which is no more, nor less, than just that): Input impedance of the load (power amp, in this case) should be at least ten times the output impedance of the source (preamp, in this case).
    https://electronics.stackexchange.com/questions/46948/the-10x-rule-for-impedance-bridging
    The nominal input impedance of the amp and output impedance of the preamp should be available from their manufacturers' specifications.
    FWIW. The most telling symptom, I think, is this (from the first post of the thread:
    ...This hiss gets louder with each step up in volume and once an increment of 10 is achieved, the hiss steps back down again...
    I am assuming that this preamp uses a resistive attenuator, which is not a constant impedance device. The maximum impedance of a resistive type volume control is, I have been told, maximum at an intermediate level of attenuation somewhere in the middle of its adjustment range, and it is not uncommon for a component (preamp, integrated amp, or receiver) to display a maximum level of hum at an intermediate setting of the "volume control".
    Now, hum is not hiss*, and perhaps the attenuator in the component in question is a constant impedance network rather than simply adjustable resistance, but I am guessing that the symptom arises from an impedance issue of some sort.
    Just a cluster of SWAGs, though.
    ______________
    * FWIW: "hiss", in my experience, is usually thermionic noise (tubes) or "shot noise" (transistors), and is also usually most audible at minimum attenuation ("high volume" settings).
    edited January 2019
    The amplifier specs...
    2 Hz to 85 kHz (–3 dB)
    Distortion: Less than 0.5%
    Power Bandwidth: 24 Hz to 28 kHz without filters
    Line Inputs: 1RCA
    Input Impedance: 100 K ohms (RCA)
    Gain: 30 dB (8 ohms)
    Tube Complement: One 12AX7, one 12AT7, one 6AL5, six KT120
    Hum and Noise: Better than 120 dB, referred to 350 watts, A-weighted
    Preamp specs for the X0.2
    Gain 14dB or 20dB
    Gain adjustment Internal
    Number of volume control steps 72
    Freq. Response -3dB @ 2Hz, -3dB @ 100kHz
    Distortion @ 1KHz <0.1% THD typ, 0.003% @ 2V
    Output Voltage 20 Balanced, 7 Single-ended
    Output Impedance 750 Balanced, 150 Single-ended
    Input Impedance 20K Balanced, 10K Single-ended
    Number of gain paths 4
    Separate analog channels Yes
    Remote control Yes
    Input voltage before overload 11
    CMRR 80db 20-20kHz
    Output noise floor -110dBV ref to 20V output
    Crosstalk typ. -90dB 20 - 20kHz
    External amp turn on
    Single-ended only inputs 5
    Balanced / single ended inputs 6
    Mono operation setting Yes
    Unity gain setting Yes
    Power Supply External
    Power consumption 30 watts
    Number of chassis Dimensions 3
    Weight 72
    edited January 2019
    amp input impedance: 100,000 ohms (unbalanced) -- no spec for balanced*
    preamp output impedance: 150 ohm (unbalanced), 750 ohm (balanced)
    Certainly no mismatch between the two for an unbalanced connection.
    Are you running balanced or unbalanced?
    ___________
    * Presumably also high -- does the amp have balance inputs?
    Unbalanced between amp and pre. The amp does not have balanced input.
    The "X" gear is really designed to be run balanced. It can run unbalanced, but perhaps this is part or all of your issue?
    If your read closely between the lines in the owner's manuals of most, if not all, X gear, it's suggested to run balanced for best results and performance.
    Just throwing that out there.
    edited January 2019
    Integrating the content of the two posts above :)
    If I were @nooshinjohn, I'd try a different set of cables 'twixt preamp and power amplifier. Couldn't hoit ;)
    Oh, I assume it does this independent of source input, yes? In other words, if (for example) the preamp has no inputs at all connected, it will still manifest the hiss at some intermediate attenuation (volume) levels, yes?
    I did H9... The X0.2 also runs at full output at all times, using a unique resistive attenuator to adjust the volume. The X1 does not, and I think that may be what the speakers are picking up.
  • bikerboybikerboy Posts: 1,167
    Preamp output impedance is 150 ohms and the amp input is 100k ohms. Thats the problem. Unless I am reading it wrong.
    Main system: Lyngdorf TDAI 2170 w/ Pioneer 42" plazma-> Polk LSiM 703 and 10" sub w/Tivo, Marantz tuner, BRP, Nothingham Spacedeck-> DV 10x5-> Bottlehead Eros, Sony cassette deck
    Digital: I3 pc w/ Jriver playing flac -> Sonore Ultrarendu -> Twisted Pair Audio ESS 9028 w/ Mercury IVY
    Vinyl rips-> ESI [email protected]/192->fanless i3 pc server
    Yes, it does this independent of source selected and is still present even with no source connected to the preamp. The hiss is present even if the attenuation is set to zero. It is also present in both left and right channels, with or without the SDA connection. In my mind, that eliminates cables or source components from being an issue.
    It would appear to be exclusive to the preamp itself, or in the match between amps and preamp.
    edited January 2019
    I am also thinking if they at Pass Labs can isolate your issue, maybe they could offer something or a suggestion to lessen the effects. They're pretty good that way. Have you looked in the Pass Labs forum on DIY audio to see if anyone else with similar gear has experienced this? That's an amazing resource and Papa interacts a lot in the DIY forum.
    Might want to have a look see over there
Howdy, Stranger!
