For You Vinyl Guys
SCompRacer
SCompRacer Posts: 9,122
edited January 2019 in The Clubhouse
  • joecoulson
    joecoulson Posts: 4,943
    That’s awesome. I’d never get away with it though
  • K_M
    K_M Posts: 1,631
    would you have to vacuum it in a circle? ;)
    txcoastal1 Posts: 13,519
    K_M wrote: »
    And adjust your vacuum cleaner tracking
  • erniejade
    erniejade Posts: 6,321
    That is cool. I like the blue one.
  • erniejade
    Ordered 2. In the den, I will put them under the KEF stands.
    treitz3 Posts: 20,119
    Talk about static noise.....
    Think about that for a second....
    treitz3 wrote: »
    Shut up Tom
  • mlistens03
    mlistens03 Posts: 2,767
    edited January 2019
    From a different thread, but I thought it would go well...
    I was lookin' at the graphics on the spiffy outer packaging of our new Dyson V8 :) vacuum, and I had a sudden realization.
    If this whole vacuum cleaner thing doesn't work out for Dyson, he/they can rescale their drawings for these vacuum cleaners and introduce a line of tone arms.
    B)
    In all seriousness, that is pretty cool, although I don’t think I would use one.
  • treitz3 wrote: »
    Okay ...... DONE.
    Awaiting further instructions.
  • erniejade
    treitz3 wrote: »
    Okay ...... DONE.
    Is that why I see smoke?
  • jdjohn
    jdjohn Posts: 3,384
    erniejade wrote: »
    You mean the one that has "45 1/3" on it? :D
  • erniejade
    12" 45. Yep
  • jdjohn
    jdjohn Posts: 3,384
    erniejade wrote: »
    12" 45. Yep
    Well...12" 45RPM is legit. 45 1/3RPM at any size is not legit.
