Best speaker wire
11213141517
  • pitdogg2pitdogg2 Posts: 14,059
    edited January 5
    PSOVLSK wrote: »
    BlueFox wrote: »
    I would have to disagree here. Just like a river. Atoms, molecules and electrons can and will move ever so slightly to create the path of least resistance.
    I disagree here. At the atomic level, any atom behavior is theoretical. My personal feeling is, at least for cables, atoms in wire are random until they are exposed to an electrical current. If the current is constant then they will align to allow the current to pass with least resistance. This result is audible if the associated gear is adequate.
    You guys are getting so over my head. :D :(
    Only cause you're 3'2" with a 10" deck
  • lightman1lightman1 Posts: 10,437
    Nope... I've met pishvolks... Strait up guy when he stands at 3'1"....
  • audioluvraudioluvr Posts: 1,302
    BlueFox wrote: »
    My personal feeling is...
    Uh. That science is hooey?
    Home System:
    SDA 1C's - Full mod with the help by Dave...
    1000 Va Dreadnought- w/ WireWorld Mini-Eclipse cables
    WireWorld Mini-Eclipse 7 speaker cables
    WireWorld Silver Eclipse IC's
    Cambridge Audio Azur 851N - DAC/Streamer
    B&K Reference 50 Pre/Pro
    B&K M200 Sonata Monoblocks
    BLE-Design 16mm Power Cables
    Denon DVD 2900
    Barn system:
    SDA SRS 2.3's Full mod done by myself
    Carver C-1 pre
    Carver M1.5t
    BluDenso - Bluetooth receiver/DAC
  • txcoastal1txcoastal1 Posts: 10,571
    edited January 5
    lightman1 wrote: »
    What's funnier (if thats a word FU I'm from TX)....he sounds more country than anyone at LSAF....and lives in the country...but never owned a pair of boots :/
    And yeah...he's got a big deck...He lives in TX
  • DarqueKnightDarqueKnight Posts: 6,559
    audioluvr wrote: »
    BlueFox wrote: »
    Does this theoretical alignment and improved conductivity in the metal wire persist after the current is removed? If it does, then that would be an example of wire breaking in.
    If the theorized alignment does not persist in the absence of external force (current, electric field), then that would not be an example of break in.
    "So hot it burns Mice!"~DK
    "Polk SDA-SRSs are hopelessly out of date both sonically and technologically... I see no value whatsoever in older SDA speakers."~Audio Asylum Member
    "Knowledge, without understanding, is a path to failure."~DK
    "Those who irrationally rail against something or someone that is no threat to them, actually desire (or desire to be like) the thing or person they are railing against."~DK
    At what point in y'alls life did you forget how to live?
    Seems that there are are those here that might offer most of us planes an insight.
  • PSOVLSKPSOVLSK Posts: 4,094
    I guess if I owned a pair of boots I might be 3'2".
    Ron, to make it even funnier (yeah, it's a word), I lived in the city for over 25 years with this Texas drawl.
  • HermitismHermitism Posts: 2,530
    PSOVLSK wrote: »
    I can hook you up with a pair of size 11. No charge for the toe jam.
    2.0/3.0 - Marantz: PM8005 w/HT Bypass, NA8005 | Polk: LSiM703, LSiM706c | PS Audio: Duet, Power Port Classic, PerfectWave AC5 x3 PC | Wireworld Equinox 7 IC | AudioPrism Quietline MkIII x7 | Sanus UF30 | Acoustic Panels, GIK Soffit Traps
    6.1 - Pioneer Elite SC-05 | Pio BDP-51FD | Polk: RTi8, CSi5, F/Xi3, CSi3 | HSU Research VTF-2 MK4 | PS Audio: Quintet, Power Port Classic | DCF124BW x3 SC | Pangea: AC-9SE x2, 14SE, 14 PC | AQ Chocolate x2 HDMI | M850SW | Acoustic Panels, GIK Soffit Traps
  • I change my speaker wire every time I change my speakers. From amp to drivers with least resistance possible from connections, if any copper connections silver plated. I feel an upgraded tweeters capacitor has great benefits per pound in the amp to loudspeaker driver's line. Low indulgence speaker wire seems to be best for me
  • I must add the benefits to getting loudspeaker crossover out of the cabinets and as close to the amp as possible. It's cleared up sound in every system I have done this to.
    Doing this may have added cost with the extra run of wires yet a lot of people have bi-wire cabling (unfortunately without bi-amping) so it makes more sense to me to try it out.
  • gmcmangmcman Posts: 1,482
    edited January 6
    Re-edited for content, sorry.
    First off, going back to the day of my RT800's and the opening of the rabbit hole. I went over to my mom's a few weeks ago and she said..."Do you have any need for this speaker wire" I set up a pair of bookies for her a long while ago and used my old monster cable..she has since re-arranged her living room minus the speakers....talk about a flashback.
    Anyway, this is where it started. I received a great deal at the time on some AQ Crystal and that transformed my system, this happened back in approx 1998.
    I've since moved on from the AQ but made me an instant believer.
    I meant to post this video in another thread a ways back. I was going to get a more controlled test with better recording gear but I've had this video sitting around so I figure why not.
    Sorry, but this goes off topic but still a cable thread, forgive me.
    During an older discussion of power cords, I swapped my AC-5's from the source, pre, and amp...to the stock cords. At the time I also tried a blue fuse in the preamp.
    You can't hear much difference in the fuse in the recording, but I can clearly hear the difference in the power cords, even using headphones on my smartphone.
    This is a track I'm very familiar with and the difference was noticeable. The track is "Don't Give Up" In my gear, Kate Bush's vocals have gone from just smooth and high to having a good bit of soul.
    The entire track sounds different, but given my recording gear at the time, the two lyrics to focus on are "somewhere" and "place", the "o" in somewhere, the "a" in place. The "a" actually sounds like "ay".
    Stock cords sound flat with very small rise in pitch.
    AC-5's bring out the distinct rising pitch and the air in her voice.
    I tried to convince myself that the stock cords sounded good when I hear the video, but they are quickly trumped by the upgraded cords.
    Just some fun, but I want to say it kinda has some merit here.
  • verbverb Posts: 7,404
    audioluvr wrote: »
    BlueFox wrote: »
    I've learned to respect, and trust, the opinions and experience, of others on this forum.
    As most of you, I started out with lamp cord (moved away from 22 gauge wire), or equivalent. Currently running MIT T2's on most of my rigs, based on recommendations from members of this group.
    Moving on to IC's now, and eventually power cords. And for this newbie's ears, I've heard the differences.
    Yes I was skeptical at first, but what the heck, decided to give it a try.
    That's the wonderful thing about this hobby - when you notice an improvement, you say to yourself, wow, that does make a difference!
    And the journey continues! :smile:
    Basement: Polk SDA SRS, Cary SLP-05 Pre, Enlightened Audio Designs CD Transport, Northstar Designs Excelsio DAC, Silnote Morpheus Ref2 Digital Cable, Marantz SA-14 SACD, McIntosh MC300 Amp, Furman 15PFi Power Conditioner, Pangea Power Cables, Wireworld Oasis 8 RCA IC's, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
    Office: PC, EAR Acute CD Player, EAR 834L Pre, PASS ACA Monoblocks, Denon UDR-F10 Cassette, Acoustic Technologies Classic FR Speakers, SVS SB12 Plus sub, MIT AVt2 speaker cables, IFI Purifier2, AQ Cinnamon USB cable, Groneberg Quatro Reference IC's
    Spare Room: , Antique Sound Labs Wave AV-8 Monoblocks, Tisbury Mini Passive Pre, Tjoeb 99 tube CD player (modified Marantz CD-38), Analysis Plus Oval 9's, Zu Jumpers, AudioEngine B1 Streamer, Klipsch RB-61 v2, SVS PB1000 sub, Blue Jeans RCA IC's
    Living Room: Peachtree Nova Integrated, Cambridge CXN v2 Streamer, Furman 15PFi Power Conditioner, Polk RT265 In Wall Speakers, Polk DSW Pro 660wi sub
  • StewartHolmes83StewartHolmes83 Posts: 20
    edited January 6
    Shielded power cables and mains filters have just recently transformed the sound and visual on any of my set ups.
    I will not start a set up anywhere without them getting involved. Both hifi and DJ equipment.
    I personally have to change other things in speaker crossover again so am sure I will always start with those.
    I find greatest benefit from budget gear. Although I have upgraded internal power supplies in the equipment tested.
    20+ years of self confessed ignorance 🤫 not like I didn't want to try or believe, just never bothered, how wrong I was.
    I even goe as far as direct lead to internal power supply, silver solder, silver/gold plated plug pins, Russell Andrews wall sockets. It may be worthy as I upgrade Amps/players in future.
    Power leads and conditioners give better picture quality on TVs too, more so older electronics in general
  • gdphotogdphoto Posts: 149
    edited January 7
    Call me crazy, but after only 8 hours these new Furez 12/4's have smoothed out nicely. They started sounding better after only 4 hours. They were very bright sounding like listening to an early CD. Fatiguing. I was quit disappointed with the results last week. I am much happier now. Thanks for the great input.
    Post edited by gdphoto on
    Hafler DH220 Power amp Recapped
    Hafler DH110 Preamp Recapped
    Hafler Digital FM Tuner
    Virtue Audio M1 Piano CD Player
    Technics SL-1210-MK5 with a Rega Exact Cartridge
    Polk SDA1c's(Rebuilt XO's by Ben) RDO194 Tweeters
  • joecoulsonjoecoulson Posts: 3,349
    Two things going on here IMO
    The cables obviously are breaking in and also your ears are getting used to the new sound of these cables as they are different from what you had. In the words of the Matrix “he is starting to believe”
    Auralic Vega G1/Rega TT/Denon SACD - PS Audio SGC - PS Audio M700x2 - Elac Adante AF-61
  • tonybtonyb Posts: 31,297
    Ha Joe....it's a blue or red pill when it comes to cables. :)
    B&k 1430
    Tad 803 speakers
  • mhardy6647mhardy6647 Posts: 22,660
    The blue pill?!
    Well, buy some cables and You’ll stay in wonderland and I’ll show you just how far the rabbit hole goes down.
    Skip,
    Check your PM's
    Home System:
    Denon DVD 2900
    Barn system:
    Carver C-1 pre
    Carver M1.5t
  • DSkipDSkip Posts: 16,065
    audioluvr wrote: »
    Skip,
    Check your PM's
    For? Not seeing anything.
    These wireworld speaker cables are freaking me out. Detail is superb.
    Home System:
    Denon DVD 2900
    Barn system:
    Carver C-1 pre
    Carver M1.5t
    edited January 9
    audioluvr wrote: »
    Placebo....lol.
    Glad your digging 'em. Try this little experiment. Listen to the new cables for about a month, then put the old ones back in. You'll be shocked.
    B&k 1430
    Tad 803 speakers
    Morning tony!
    Mornin' Joe....got the coffee pumpin' ?
    B&k 1430
    Tad 803 speakers
    Darn right!
    tonyb wrote: »
    audioluvr wrote: »
    Placebo....lol.
    Only he hooks 'em to the wrong connections...
  • vcwatkinsvcwatkins Posts: 1,905
    audioluvr wrote: »
    Is this the source of your freak-out? ->> WireWorld Mini-Eclipse 7 speaker cables
    Den: Rega RP6 * AT33PTGII * Budgie SUT * Jolida jd9 * Roon (Sonic Transporter) * PS Audio DirectStream Jr. * Joule-Electra LA-100 mkIII * Sunfire Signature II * PSAudio Power Plant 3 * MIT S3 * Polk SRS 1.2
    Office: Roon * Sonore UltraRendu (LPS-1, WW Plat7, Iso Regen, Lush) * ProJect Pre Box S2 * Pass ACA * PSA Dectet * DH Labs Q10 * Brines Folded ML-TQWT RS 40-1354
    Beach: Music Hall MMF5.1se * Speed Box II * DL103r * Lounge Copla/LCRIII * W4S Sonos * Schiit Yggdrasil * Belles 20a Pre * First Watt F5 Clone * PSA Dectet * MIT S3 * Polk SRS 2.3tl
    vcwatkins wrote: »
    audioluvr wrote: »
    Yes. My daughter and I were playing Rush Exit Stage Left last night with the lights out and I think during The Trees she said "Dad I think I heard something behind me...".
    Home System:
    Denon DVD 2900
    Barn system:
    Carver C-1 pre
    Carver M1.5t
    Careful guys, you'll end up like Jesse and Ken.
  • F1nutF1nut Posts: 42,505
    We shouldn't have to be careful about pointing out the obvious. The issue should have been dealt with a long time ago.
Howdy, Stranger!
