Got New Speakers, now Which Receiver
Hi. Just got the T series at Wal Mart - (awesome by, 2 t15s, t30 and 2 t50s for 149.00). I had part of the tseries before and loved them but had to move and pawned them so I had money to move.
I have them paired with junk right now (RCA 2781 BT) https://www.walmart.com/ip/RCA-Bluetooth-Home-Theater-System/105223402?wmlspartner=wlpa&selectedSellerId=0&adid=22222222227040083346&wl0=&wl1=g&wl2=c&wl3=91186959032&wl4=aud-566049426705:pla-185700914192&wl5=9026105&wl6=&wl7=&wl8=&wl9=pla&wl10=8175035&wl11=online&wl12=105223402&wl13=&veh=sem&gclid=Cj0KCQiAjszhBRDgARIsAH8KgvflhpOgTvIvpDBylbowbyeu9XRcbcORnwmlG1X8r-Fu9XA2oMcozb4aAjC5EALw_wcB
Before I had a Sony DH 550 5.1. Loved it, got it for like 50.00 at a pawn shop. I could adjust the bass, treble and more. This RCA, I've got through Optical hookups and can't adjust anything. So, I'm wanting to delegate the RCA to the spare room TV and get a new Receiver. I will also need a sub, thinking of the PSW 108 or 110.
Which receiver should I go for paired with the t-series?
  • rooftop59
    rooftop59 Posts: 8,121
    edited January 2019
    Those speakers don’t need much power, but I have not found Sony to have very good sound quality. I would go with whatever Yamaha or denon you can afford. Marantz slimline is another possibility. Check accessories4less.com
    Game Room 5.1.4:
    Bedroom 2.1
  • mrloren
    mrloren Posts: 2,474
    ^^^what he said^^^
    What's your budget?
  • I would say up to 400-500.00.
  • sponger
    sponger Posts: 325
    The denon x2400h and x3400h are $400 and $600, respectively, on amazon and probably crutchfield too. The x2400h would serve your needs plenty, but I think the difference for the x3400h would be worth it since it has pre-outs for an external amplifier in case you upgrade the speakers down the road.
    Denon X7200WA
    LSiM 705 703 704c
    Denon DP 400
    Yamaha CDC 775
  • mrloren
