Dreadnought Case Interest Check...
So with the Group-buy-2019-dreadnought-avel-lindberg-1000va-isolation-transformers I figured I would start a new thread to see who is all going to be wanting one, and see if it's going to be worth running them, I will do my best to keep the same cost as the last runs, but aluminum has gone up since the tariffs as well as Black Anodizing that I would use for the side panels..
My thought is if cost becomes an issue, and to keep cost down we could cut out the Black Anodizing for the side panels and just Powder Coat them a Smooth Black, and keep the case a Texture Black, that way we still have the contrast with the two colors, let me know your thoughts on this, if everyone is okay with this it shouldn't be a problem on cost as I can have the powder done in house, and cut out the outside process..
The cost on the last run's was $100 shipped...
Reminder: If you already have one of my cases, they fit both the 800va and the 1000va, so if you are just upgrading to the 1000va there is no need to buy another case if you don't want to...
«13
  • pitdogg2pitdogg2 Posts: 15,911
    edited January 2019
    Count me in Larry.
    Thanks for your time and expertise
    I'm good with the powder coat to keep cost down as well.
  • BC6BC6 Posts: 109
    I'm in. Thanks!
    2 Channel: Atohm GT-1 speakers, Atoll IN400 integrated amp, PS Audio DirectStream DAC, PS Audio NuWave Phono Converter, Pro-Ject Debut Carbon Esprit SB with Ortofon Bronze cartridge, SotM sMS-200 ultra streamer, SotM sPS-500 power supply, and homemade infinite baffle subwoofer with two Fi Audio IB318 drivers.
    HT: All Polk: SDA 2.3tl fronts, CSiA6 center, 500-LS ceiling, RT/FX, RTi8, Monitor 4 rears, plus Yamaha CX-a5100 AV Preamplifier/Processor, Yamaha MX-a5000 11.1 channel amplifier, and Sony XBR55-AE1 OLED TV.
  • ManticoreManticore Posts: 408
    Count me in also. Black Anodized sounds great!! Either way in.
    Denon AVR X4200W
    Parasound A23 amplifier
    LG 65" Ultra HD4k
    LG 4kBR - UP970
    Denon DVM 4800
    Denon DP 3000 turntable
    Saec 308sx tonearm w/
    Dynavector 10x5 cart
    Vincent PHO 701 Phono Preamp
    MIT Avt3 Speaker c's
    Audio Quest Big Sur ic's
    Polk SDA 1C's modded
    Polk LSim 707
    Polk LSiM706c
    Polk RTiA 3's
    Polk 80F/X-RT
    Polk DSW PRO 440wi sub
    Infinity bu2 sub
    "The early Klingon gets the Gagh"
  • ThomasDThomasD Posts: 259
    @Toolfan66
    Your tentative cost of $100 is more than fair and not a concern to me. If a pair of qualifying SDA's present themselves, the positioning of the 'Dreadnought' in my system would be in a visually dominating location and basically 'on display'. I'd probably be looking at having the case engraved and some custom grey anodizing to more closely match my 'Carver' gear. Is just the natural, un-textured aluminum finish an option? Thanks
    Carver M4.0t, M1.0t, M200t, TX2, C1, C2, Marantz 2230, 2010, 4070, 1030, APPJ 2013, Rega Brio, Marantz Imperial 7's, Klipsch Heresy III, Quartets, KG4's, KG1's, 'The Sixes', R-12SW, Polk SDA 2a's, Monitor 7cTL's, SDA CRS's, 4a's, Zu Audio Dirty Weekends, Pro-ject Acryl TT, Cambridge 851N, 351C, Panamax 5300PM
  • Gerres26Gerres26 Posts: 584
    Larry, do you have any pics of the last run you did? Anodized does sound nice but not if it runs the cost up too high.
  • RobbyKYRobbyKY Posts: 116
    The black anodizing on the end panels from the last run is a beautiful contrast to the powder coat on the body. Hard to capture black on black with a simple iPhone. And yes, I've not gotten around to sourcing out some decent knobs for the spikes yet...
    I would consider a grey version if you could match the old Carver gear like ThomasD suggested as this next unit will operate with a set of Carver M-4.0t amps but I'm perfectly happy with whatever the group direction is. Of course, Bob couldn't match colors himself between production runs so picking which version of "Carver Grey" would be a monumental task without a specific sample I would think?? My current dreadnought operates with a set of TFM-55's that are black and I bought a new black faceplate for the C-1 preamp off the 'bay to be all matchy/matchy.
    Put me down for one (1) case this go-round please!!
    Robby
    Media Room: Parasound JC-5, Cambridge 851N, Schiit Freya, SDA SRS 1.2tl
    Game Room: Carver M4.0t, Carver C-4000, Oppo BDP-105, SDA SRS 1.2tl
    Bar/Card Room: Carver TFM-55, Carver C-1(BillD), Oppo BDP-93, SDA SRS 3.1
    Son's Room: Carver TFM-55, Carver C-1(BillD), Laptop/AQ Dragonfly, SDA SRS 3.1
    Bedroom: McIntosh MC150, Cambridge CXN, SDA 2Btl
    Outdoor Pool Area: Yamaha R-N803 with four Polk Atrium 6
    HT: Polk RTi A9s, CSi-A6, RT-65, RTi-A3's, Marantz SR5012, XPA3, UDP-203, Epson 5040UB
  • lightman1lightman1 Posts: 10,605
    In for one case. Thanks Larry!
  • audioluvraudioluvr Posts: 1,976
    I'm in for a plain one.
    One foot on audio nirvana and the other in the poor house.
  • As long as I got in on the transformer buy, I'm in for one of these.
    Speakers
    Polk 5jr+
    Polk SDA 2B
    Polk SDS 3.1TL
    Equipment
    Yamaha RX-V3800 Receiver
    Analog Sources: Sony TC-K890ES Cassette, Nakamichi DR-1 Cassette, Technics SL-7 Turntable
  • daddyjtdaddyjt Posts: 1,303
    In for one (1) please. I have one of your other (silver sides) cases, and it is top notch. I am not concerned about finish/color on this one.
    Too much stuff to keep track of.
    Currently enjoying: Legacy Focus 20/20, McCormack DNA 225, Bill D C1, Oppo 105
    RobbyKY wrote: »
    Robby
    Let it be known that the outrigger feet are NOT included
    What?! That may be a deal breaker!! ;);)
    Nope, those are 80/20 "10 Series" 4199 pivot arm parts. I use a lot of their stuff and had these laying around. The small ones are about $5 each but they show out of stock on Amazon lately. Just bought some direct so still in production.
    You can find them here:
    https://8020.net/shop/4199.html[/url]
    They also come in black but I liked the contrast:
    https://8020.net/shop/4199-black.html
    Robby
  • gudnoyezgudnoyez Posts: 7,260
    I made the cut so yes Larry put me down for one, I'm pretty sure the one on my800va is one of yours fine workmanship indeed. I'm down for one of these from the new run . Thanks
  • verbverb Posts: 9,759
    I’m in! Thanks Larry for doing this!
    Basement: Polk SDA SRS,Cary SLP-05 Pre,Enlightened Audio Designs CD Transport,Northstar Designs Excelsio DAC,Cambridge 851N streamer,Marantz SA-14 SACD,McIntosh MC300 Amp,Silnote Morpheus Ref2 Digital Cable,Furman 15PFi Power Conditioner,Pangea Power Cables,Wireworld Oasis 8 RCA IC's,MIT Shotgun S3 IC's,MIT Shotgun S1 Bi-Wire speaker cables
    Office: PC,EAR Acute CD Player,EAR 834L Pre,Northstar Designs Intenso DAC,PASS ACA Monoblocks,Denon UDR-F10 Cassette,Acoustic Technologies Classic FR Speakers,SVS SB12 Plus sub,MIT AVt2 speaker cables,IFI Purifier2,AQ Cinnamon USB cable,Groneberg Quatro Reference IC's
    Spare Room: Antique Sound Labs Wave AV-8 Monoblocks,Tisbury Mini Passive Pre,Tjoeb 99 tube CD player (modified Marantz CD-38),Analysis Plus Oval 9's,Zu Jumpers,AudioEngine B1 Streamer,Klipsch RB-61 v2,SVS PB1000 sub,Blue Jeans RCA IC's
    Living Room: Peachtree Nova Integrated,Cambridge CXN v2 Streamer,Rotel RCD-1072 CD player,Furman 15PFi Power Conditioner,Polk RT265 In Wall Speakers,Polk DSW Pro 660wi sub
  • la2vegasla2vegas Posts: 4,139
    I'm in, thanks for your help with this Larry.
    Much nicer than my Hammond version...I'm in for one please!
  • Hey what happened to the last thread from this morning?
    Anyway I’m in for one
  • indyhawgindyhawg Posts: 1,428
    Larry--Count me in.
  • Thanks Larry, for your generosity of time and effort.... I'm in for 2.
    Doug
    2 Channel - polk 2.3tl's, (2) Carver Crimson 275 Tube amps,(built by me at CF2018), Vpi Scout 1.1, Ortofon 2m red ,Schitt's Mani Phono Pre, 10 Octave Audio LP1 Linestage Tube Preamp, Carver C-11 BillD, Carver SD/A 490t, Carver Tx-11b, Logitech Media Server, Dreadnought 1000va (Built/Assembled/Me), Douglas "Bravo" Interconnects, Speaker cables(diy), Monster HTC 5000 Powercenter
    Am I correct in assuming that these 1 KVA torrids don’t generate any appreciable heat when used in this SDA IC configuration? I see no venting on the cabinets so no ventilation issues?
    Never any heat
  • gmcmangmcman Posts: 1,529
    I'm in for one case.
    Thank you again Larry.
  • erniejadeerniejade Posts: 5,274
    I'm in please
    Den: Lumin D1,Wireworld Silver Eclipse RCA, KEF LS50 Wireless, Velodyne SPL1200, Technics 1200, Denon DL160, Jolida D9,
    Living Room:,T+A PA 1530R, Tyler Highland H2, High Fidelity Reveal RCA, PS Audio Direct Stream JR. Wireworld Silver Eclipse SC
    Have but haven't used in a while: LH Labs VI Dac, Cayin SCD50T, Aries Mini, Grant Fidelity Tube Dac 11, W4S recovery, Massdrop Airist Audio R-2R dac
  • Put me down for a case please.
    I plan to terminate my cable directly inside the box without fancy terminals. Already have an updated heavy gauge cable with speakon terminals.
    One less link in the chain.
    Any downside I’m missing besides the bling factor?
    So Larry @Toolfan66 getting my read on about the whole dreadnaught thing, and found this:
    https://forum.polkaudio.com/discussion/166261/finally-neutrik-dreadnought-etc
    Gotta admit, those red panels look great, not to mention the other bling mods you made! Wow! :smiley:
    Is this group buy only black panels this time? :blush:
  • monepolkmonepolk Posts: 1,071
    Put me down for 1!
    verb wrote: »
    verb wrote: »
    @Toolfan66 I for one would sure consider paying an up charge for a different anodizing option. B)
  • B-ManB-Man Posts: 13
    Larry - thanks for your generosity. Please put me down for 2.
Howdy, Stranger!
