PSW10, T15s, and SMSL SA50 50Wx2 amplifier for PC set up
Rivie
Rivie Posts: 3
Hi,
I'm new here and I hope someone with much more experience than myself can point me in the right direction. I have a PSW10 with 2 T15s, and SMSL SA50 50Wx2 amplifier that I want to hook up to my PC. What would be the best way to set this up making sure I do not damage the PSW10? My fear is that because I have to hook up the SMSL amplifier to the PSW10s speaker input and the T15s to the PSW10s speaker output to be able to power them, that because both the sub and the amp are powered it may both dirty up the signal as well as have too much of an amplified signal. Not sure if the crossover in the amp takes care of this. I also thought of using y splinters to send one to the amp and the other to the sub, but that would have the T15s dealing with the low frequency that the sub should be handling. Hope I'm not making this more complicated than it is. Any and all help is certainly welcome and greatly appreciated.
Best Answer
  • tonyp063
    tonyp063 Posts: 1,135
    Answer ✓
    ....hook up the SMSL amplifier to the PSW10s speaker input and the T15s to the PSW10s speaker output to be able to power them,
    This is the correct method for the components you have. Do *not* use a Y splitter
    That SMSL does not have a separate low-level sub out.
    The crossover for the sub does what you need. I'd suggest you set the sub crossover at about 100Hz to start & adjust for your taste
Answers
