Subwoofer cables
daboyz
Budget minded. Need two lengths anywhere above 7ft.
Around and below $50 shipped.
Thanks!
Thanks!
I could make you a pair with RG6. Then you just put an rca adapter on each end. I can make them any length you need. I have high quality RG6 with great shielding. I use quality fittings to.
If you like , let me know. I would charge far less than your budgeted $50.00.
That's a good idea! Didn't think of it. I'll let you know. Thanks!
So I just looked up cost of RG6 and it's pretty cheap these days. Here is 35ft for $7.00.
https://www.amazon.com/dp/B015USMQRQ/ref=cm_sw_r_cp_apa_i_girlCbW9HYGCW
Then you just screw these RG6 to RCA fittings on and you have a very well shielded rca cable. They are great for long runs. I run two 35ft myself and complaints.
https://www.amazon.com/dp/B01HAVUBRS/ref=cm_sw_r_cp_apa_i_qlrlCbV0ESKZD
I did not know they were available for so cheap. I really can't compete price wise.
I'm out of the rca adapters. They would have to be sourced from Amazon or another retailer. I can still make the cable but after shipping I think it would be a little more than what I showed you in the links. -
PM INBOUND
or you just buy raw cable and put on the RCA ends. EASY PEASY do it all the time. I have plenty of the quad shield cable laying around.
I've got a few laying around. Have a Pangea that's a good 10 ft, 25 bucks shipped to your door.HT SYSTEM-
lsi 9's -
Thanks all. I bought a pair of AQ's off the bay so I'm good.
