Lfe input question
I don't know much about this stuff, but if I connect my Onkyo 805 to my psw125 with the lfe input on the sub, does that mean that my bass for my system is moved to just my sub? If I connect it to where I control the levels, does that allow my RTi a7 to produced more bass? I was confused on this. Thank you for your help!
    txcoastal1 Posts: 13,514
    Use the LFE and in the receiver settings set speakers to small and try 80hz
    This will send all bass signal below 80hz to the sub and take some of the weight off your receiver amp
  • Thanks. I am going to try that!
  • helpful to me too
