Anyone have a SVS PB12-NSD Subwoofer?
Milito
Milito Posts: 2,003
They are on sale at SVS: https://www.svsound.com/collections/nsd-series/products/pb12-nsd
What do you think of this sub?
How does it compare to the VTF-2 MK5 Subwoofer?
Which one would you buy?
  • ken brydson
    ken brydson Posts: 9,027
    I haven't heard that model but for $500, 45 day trial and free shipping kinda a no brainer....
  • polrbehr
    polrbehr Posts: 2,852
    edited November 2018
    +1, the "trial" is kind of a Jedi mind trick, I can't imagine too many people sending these products back because they under-performed. If anything, I would think it would only get folks contemplating adding a 2nd one.
    No comment on the VTF-2 however, I honestly never heard one of them. Can you try both and send back the one you liked less? FWIW I do have an SVS, it's an 11yo PB12-NSD/2 that's still going strong.
  • Milito
    Milito Posts: 2,003
    The VTF-2 is $77.00 more shipped and from the reviews I've read it is rated better. It also has more tuning options on the amp and has 2 ports instead of the one on the SVS. I'm thinking the VTF-2 is the way I'm going to go, but I'm going to wait and see what Black Friday has to offer.
  • Milito
    Milito Posts: 2,003
    Ordered the VTF-2 MK5 today. I can't put anything bigger in the space I have to put it in. Bad part of it is I have to wait till Christmas to use it although I will have to check it out to see if it works. That's what I'm telling the wife anyway, then I put it back in the box.
    However I did buy a Sony 65" 900F yesterday so it's not all bad and I'm watching the Cowboy game on it now.
  • rooftop59
    rooftop59 Posts: 8,120
    Nice! I ordered one as well. Also the biggest I could fit in my custom built ins. I will be able to use it if someone else will set it up for me as I am currently on the DL.
    Game Room 5.1.4:
    Bedroom 2.1
  • displayname
    displayname Posts: 1,236
    I have the SB12-NSD in my system. It took a little while to get it decently integrated, but it works well. I have considered adding a second as well.
    Discogs
