Adding a power amplifier to my system and have a few questions.
jomat77
jomat77 Posts: 11
I am searching for a decent power amp for my system. I have the following components:
Polk LSi15's and an LSiC
Polk DSW Pro 400 Sub
HK AVR 7300
I definitely plan on adding a pair of LSi7's to use as rears and potentially LSiF/X's if I can find a good deal.
My question is this...
When I finally get an amp, do I need any other components for this system? Like a pre-amp or anything else? Or will it depend on the type of amp I get? I am searching for a 5-7 channel amp with a min of 125 wpc @ 4 ohms.
If anyone has one for sale, I am looking to buy immediately and looking to spend under $500. Also looking for advice on the best one to pick up. Thank you in advance for the help.
Answers
    txcoastal1 Posts: 13,513
    You will need an AVR with preamp outputs
    Time to upgrade anyway with an AVR that has HDMI in/outs
    Marantz, JVC, Denon, in no particular order
  • afterburnt
    afterburnt Posts: 7,892
    No pre just IC's
