Good afternoon ladies and gentlemen. This thread is dedicated to....well, read the title. Pretty self explanatory.
Today, I measured the distance of the subs/speakers to the listening position down to 1/8 of an inch including the toe in and will be messing around with dialing in the Rythmik F-25's.
What have you done for your rig today?
«134567177
  • FestYboy
    FestYboy Posts: 3,861
    Looked at it longingly knowing that it'll have to wait till after Christmas...
  • verb
    verb Posts: 10,176
    I swapped out a digital coax on the EAD transport with my new Silnote Morpheus II :smile:
    treitz3 Posts: 17,732
    Oh, after all there years...I never knew. *slaps head*
    DOH!
    mhardy6647 Posts: 32,355
    I ignored mine today :|
    Our son's home and we went to one of the local junk antique stores to prowl the aisles for treasures and/or last minute holiday gifts -- oh, and food items. The place also features a Cabot Creamery company store.... and essentially infinite free samples of Cabot products.
    A good day :)
  • delkal
    delkal Posts: 764
    I bought a pair of Zu interconnects and they came on Friday. I am supposed to burn them in for 500 hours! The way things are going for me that would be a few years of listening sessions. Not wanting to wait that long I got out my old integrated amp and a tuner. Once I got the radio playing I could turn the volume off on the amp and will just let it run for a few weeks.
    This morning I thought about my Monoprice 50 watt integrated that I recently upgraded with Russian tubes Why not burn in the tubes at the same time? Hooked this up into the mix by connecting the monoprice to the tuner then using its preamp out to the other integrated amp. Seems like everything is working well. I can turn the monoprice up higher than I would want to listen to with speakers so the tubes are getting broken in with a decent current. And when you turn the other amp off its peaceful and quiet
    Not quite sure you are burning in the cables though....and this might present an issue with the tubes not being under a load....
  • motorstereo
    motorstereo Posts: 1,969
    I took out one end of my speakon connector cable to see if I'll be able to replace it with a thicker and better quality Mit speaker cable. I'll probably need to hog out the hole a bit or use a little silicone grease or both.
  • cfrizz
    cfrizz Posts: 13,415
    Sorry Tom, but my system is a HT/Music system. But I'm listening to PP@M right now and it sounds great!
  • BlueFox
    BlueFox Posts: 15,251
    Turned it on to enjoy later tonight.
    Merry Christmas, Cathy! You still qualify, as your rig still does 2C.
    BTW, your abbreviations formed from the initial letters of other words and pronounced as a word have a 747 GOMH at an incredibly fast clip. BCOWYBS and have a great holiday!!!
    "Sounds Great" is all I needed to hear!
  • Faustin
    Faustin Posts: 1,129
    Nothing.....yet
  • cfrizz
    I have no idea what "BTW, your abbreviations formed from the initial letters of other words and pronounced as a word have a 747 GOMH at an incredibly fast clip. BCOWYBS and have a great holiday!!!" means.
    Which probably means you didn't know that PP&M stood for Peter, Paul and Mary. Sorry.
    Thank you Tom, may you have a great Holiday as well!
    GOMH - "Go over my head"
    BCOWYBS - "But go on wit'cho Bad self!"
    Shut up Trey.
    Shut up Russ.
    Not Trey.
  • delkal
    delkal Posts: 764
    edited December 2018
    treitz3 wrote: »
    I am pretty sure the interconnect and tubes are under load even though no sound is coming out of the speakers. They should be giving the signal to the integrated amp. Its just that the integrated amp isn't amplifying the signal so when the volume is turned down (on the integrated amp) I get no sound. It is kind of a unique setup. If I have both amps off then no sound. If either amp is on half way I can use the other to adjust the volume. I have the tubed pre on at over 12:00. Normally that would be too loud but with the volume on the amp off i don't hear anything. When i check on things and turn up the integrated I hear music. So the pre and interconnect is constantly sending a signal
    Or at least thats what I am hoping is happening. If you have more than one line level inputs running (like a CD player) I assume the amp is still getting getting the signals from all of the inputs. The amp is just amplifying one. (at least I hope so).
    But you have a good question. Do preamps and line level inputs draw more power as an amplifier is turned up?
    pitdogg2 Posts: 23,786
    delkal wrote: »
    treitz3 wrote: »
    Dude that's DEEEEEEP
  • joecoulson
    joecoulson Posts: 4,943
    What is the Matrix?
  • I turned it on and listened to it🤣🤣🤣
    Living Room
    Parasound HINT 6, Yamaha Aventage RX-A 1060, Yamaha BD-S681, Cambridge Audio Azur 851N, Polk S60, Polk S30, Samsung 60" LED
    Office
    Cambridge Audio 851A, Auralic Aries Mini, LSiM 703s
    Douglas Connection ICs and Cables
  • FestYboy
    delkal wrote: »
    No, they don't. The source current remains the same. That is unless there's an output gain pot in the mix, then the current is variable.
  • machone
    machone Posts: 1,438
    I tweaked speaker position
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    nooshinjohn Posts: 24,719
    Prepped it for the installation of my new(to me) Pass Labs X0.2 and Xono preamp/phono stage. When they arrived today, I gleefully opened the boxes to discover they were nowhere near the condition described. So I contacted the seller and am trying to work a solution.
    They sit outside my rack tonight, uninstalled and no music will fill my house tonight, unless it comes from my wife's crappy cellphone speakers.
    The Gear... Carver "Statement" Mono-blocks, Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
  • BlueFox
    I understand cosmetic concerns, but still, why not listen to them?
    Because I am not going to rewire my stack of stuff until I am certain it is going to stay put. The seller has stated he may want to have the gear returned, and if that is the case I would rather just do that than spend hours to wire things up, several days for the Pass to settle down and then take it all apart again.
  • verb
    verb Posts: 10,176
    Thinking about my rigs while in Vegas on vacation! :smile:
    verb wrote: »
    Drive that C8 prototype down here to L.A. and say hi. I can keep a secret. :p
  • joecoulson
    Just admired it 😬
  • mdaudioguy
    mdaudioguy Posts: 5,165
    treitz3 wrote: »
    Acronyms are hard! :p
