Suggestions for phono preamp...
Got my new to me ProJect table up and running... And guess who has an integrated with no phono pre in the rig for the table? Yeah...
So I ran out to grab one at my local vinyl shop and all that was handed to me was a Pyle unit. I wasn't thrilled, but it got the job done (for now).
Looking for better options please.
OR!!! There was a NAD 1700 pre sitting on the shelf calling me with the option to trade for it... It has a phono preamp...
  • verb
    verb Posts: 10,176
    edited December 2018
    I’m on the same quest as you my man! My Rotel pre has phono inputs but the VTL on the big rig does not. Been thinking about the Vincent PHO 700 tube pre.
    I believe there are quite a few Polkies that are running the Vincent.
  • verb
    verb Posts: 10,176
    Pyle? Really? :smile:
  • FestYboy
    FestYboy Posts: 3,861
    Yeah!!! That's all he had, I asked. Granted, he specializes in vintage equipment which typically come with them built in.
  • halo
    halo Posts: 5,616
    The Schiit Mani is a solid option and it is very reasonably priced with a lot of great reviews behind it. Very flexible too as it can accommodate a wide variety of Mm and MC carts.
    http://www.schiit.com/products/mani
  • tonyp063
    tonyp063 Posts: 1,044
    Take a look in the closeout section of their website. They have quite a few mani's there.
    A goodly amount of people speak well of the ArtDJ Pre II also.
    Don't be afraid to look at Chinesium too. I use a Little Bear T10 that is quite nice.
  • skrol
    skrol Posts: 3,330
    How would that Schiit compare to the Parasound Zphono?
    Parasound recently released the Zphono XRM that looks very interesting.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • jdjohn
    jdjohn Posts: 2,987
    For less than $100, the ART DJPre-II is hard to beat.
    What is your budget?
  • halo
    halo Posts: 5,616
    jdjohn wrote: »
    That's my "backup" phono pre. It's nice but it only handles MM carts.
    skrol wrote: »
    I had a zphono a few years ago, nice piece of gear. I think that the Mani is far more flexible in matching the carts.
  • joecoulson
    joecoulson Posts: 4,943
    Arty, since I was a help in getting that table running, I might as well throw this into the mix for you, I have a Cambridge Audio Solo I am about to sell because I upgraded. Bought it brand new about 3-4 months ago. Sell to you only for $100 shipped. Have box and all that came with it. Basically mint.
  • vcwatkins
    vcwatkins Posts: 1,993
    Used Jolida JD9 like this one on ebay, maybe?
    Can be modded easily and inexpensively to sound very good (pairs of caps, opamps, & tubes - see mod threads here, AK, & SH). The low height full width form factor is a plus in my den rig since I don't have room for multiple little boxes (and cables) to sit around.
    If multiple little boxes is not a factor, you might want to look at new Lounge/Coupla combo - excellent value, sounds very good with my limited range of MM, HoMC, and LoMC, and offers mix-and-match flexibility for future gear changes.
    Beach Audio: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Schiit Yggy * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
    treitz3 Posts: 18,230
    I will second the Jolida JD9. Nowhere near <$100 but a fine pre and it responds very well to tube rolling. There is a MKII for $50 more, FYI.
  • verb
    verb Posts: 10,176
    Interesting little guy. Lot's of good reviews out there. Pro-Ject Tube Box.
  • joecoulson
    Love how that looks.
  • Dr_Wu
    Dr_Wu Posts: 305
    For your consideration, I've enjoyed the MoFi StudioPhono, with adjustable gain, impedance, and a mono setting. I wanted the additional gain settings for a low output MM cart. Now, I'm glad I got it because it also opens up the possibility of getting an MC cart.
  • FestYboy
    I'll put it out there: tube rolling ain't in the budget, lol. I'm hoping to stay in the $100 range and @joecoulson the Cambridge might just do the trick, but some research is due. The Oyster cart isn't all that strong and a bit laid back, but that could very well be the Pyle pre...
  • vcwatkins
    Sorry, missed the $100 range.
    With a 15-day return, I would check out the $129 Schiit Mani. I think all the Schiit gear I've had has been good value.
  • joecoulson
    So’s a Cambridge Audio...just sayin
  • halo
    halo Posts: 5,616
    vcwatkins wrote: »
    B-stock is $99! 25 units available as of today. :)
  • FestYboy
    Freaking rabbit hole!!!!
    After @joecoulson graciously offered me the Cambridge, I went and looked up the specs for my cart thinking I had a LO unit (turns out it puts out a respectable 4.0mV) and came to the conclusion that, although it's miles above the ion POS TTi was running, it's still a bottom of the barrel unit.
    That being said, now I have to get a better cart, and a pre to complement it. So much for a $100 budget :s
    So now the request is for a combo that plays nice with each other. Ideally the pre will have adjustable gain, be capable of both MM and MC (will stick with MM for now), and NO TUBES. I can't afford it already, and tubes will not help the situation. The rig will consist of 2.3s driven by either my 2400PE, or GFA 545, and a NAD integrated (c320 bee), or NAD 1700 pre (MM only phono stage). Let's try to keep it under $500 total for both pieces. Keep in mind that currently it's a Sumiko oyster cart mated to a Pyle pre, so it can't get worse than that.
  • motorhead43026
    motorhead43026 Posts: 3,892
    I have the Vincent PHO-8. It is a decent $300.00 unit. The sub 500.00 field is pretty crowrded, lots to chose from.
    The Vincent is on the warm side, which appeals to my taste. There are an online retailer or two, that give a 30 day trial.
    2 channel: Anthem 225 Integrated amp; Parasound Ztuner; TechnicsTT SL1350; Vincent PHO-8 phono pre; Marantz CD6005 spinner; Polk SDA2BTL's; LAT International speaker cables, ZU Mission IC's and power cables all into a PS Audio Dectet Power center.
    Other; M10 series II, M7C's, Hafler XL600 amp, RB-980BX, Parasound HCA-1500 amp , P5 preamp, all in storage. All vintage Polk have had crossover rebuilds and tweeter upgrades.
    The best way to predict the future is to invent it.
    It is imperative that we recognize that an opinion is not a fact.
    Imagine making politics your entire personality.
  • jdjohn
    jdjohn Posts: 2,987
    FestYboy wrote: »
    Oh, it can always be worse :D So you said earlier that the Sumiko Oyster is too laid back for you. I tried a Sumiko Pearl and felt the same. Do you have a preference of bright vs warm vs analytical? Some brands have a house sound that we might be able to steer you towards.
  • jdjohn
    jdjohn Posts: 2,987
    Here's a Dynavector P-75 MkII for $319: https://www.usaudiomart.com/details/649481162-dynavector-p75-mkii-phono-stage/ You would still have room in your budget for a better cartridge, but of course you should listen to your Sumiko Oyster through this P-75 first. It may come alive for you B)
    I have that same phono preamp myself, although it has become my [cough] very nice backup for the time being. Don't let its diminutive size fool you.
  • HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
    Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
    2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
    Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
    BR - Yamaha CR800/Polk monitor 5
  • verb
    verb Posts: 10,176
  • If they won't ship, Send me the money through PP, I 'll meet the guy in Havertown and ship it to you.
  • FestYboy
    jdjohn wrote: »
    FestYboy wrote: »
    Given that my current rig is already a bit warm and easy, I think a more analytical or slightly bright cart might help to balance it out. I know my speakers are capable of far more than the cart I'm running, so the search for a better match is on.
    mhardy6647 Posts: 32,927
    were I you, I'd be careful of bright or analytical cartridges. :p
    Yes, I realize I am not you, but there are a lot of - to my ear - edgy phono cartridges. A whole slew of 'em have emanated from a company whose name rhymes with bawdy-oh plectnica, as an example :|
    Again, just the way my ears are; YEMV. :)
  • FestYboy
    I can't say I've ever been attracted to AT hardware. I've had plenty of experience with their mics, and did not like how they treated vocals or drums. My favorite mic to use for testing mixing boards was a Shure 78.
    Cannot complain about some of their (vintage) tonearms, personally. :)
    35993349896_78bda4e3b6_h.jpgDSC_8876 (4) by Mark Hardy, on Flickr
