SVS SB12 Plus - Sold
VR3
Excellent compact subwoofer! Darn near can hit almost 20hz flat!
Good condition, shows some mild wear up close and under the light but at normal distance shows very well. You will not be disappointed.
$475 shipped with paypal
https://www.audioholics.com/subwoofer-reviews/svs-sb12-plus
Sensitivity (2.83 V/1m): 86.5 dB spl
Amp. Power: BASH© High-efficiency 425W hybrid-class, digital-switching power amp
Rated Impedance: 4 Ohms
Frequency Response (+/- 3, -6, -10 dB): 22 Hz (-3 dB) - 300 Hz (+ .2 dB); 20 Hz (-6 dB) - 300 Hz (+ .2 dB); 19 Hz (-10 dB) - 300 Hz (+ .2 dB)
Bass Principle: Acoustic Suspension
Cabinet Dimensions (W x H x L): 13.5"x 13.5"x 13.5" (342.9mm x 342.9mm x 342.9mm) without grill cloth
Active Processors: Crossover: active lowpass filter, variable,40 - 120 Hz
Parametric EQ: Variable Q (.1 to .9 octave), variable attenuation level (0 to -12 dB), and variable frequency (20 –80 Hz);
Variable phase (0 –180 degrees), and Room Compensation (variable slope highpass filter) (Small, Medium, Large Bypass)
Sorry, think Im priced a little off - $425 shipped!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Can't believe no interest in this subwoofer, one of the last generations of USA svs subs- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Holidays Trey. Myself too many family birthdays next month and X-mas or i would be all over this.
GLWTS -
At first I wan't sure what advantages the plus offers over the currently discounted SB-12NSD. But the plus has CLEAR advantages over the SB12-NSD. The plus goes a bit deeper (can basically be flat to 20hz!) and has a LOT more features like an adjustable EQ and balanced inputs. Given those features this is a great deal!
GLWS!!!Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Bedroom 2.1Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer -
Yes, the nsd is the entry and the plus is the middle. Larger driver, bigger Amp, etc- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Nice sub here kids, I'd buy it myself if I had Ivans money. Good luck on the sale Trey.
….and before anyone asks, yes, this will blow away any Polk sub. So if your looking to upgrade on the cheap, this is your huckleberry.HT SYSTEM-
lsi 9's -
Appreciate the bump!
I forgot to mention that I am including that Belkin PureAV sub cable too
$400 shipped for Polkies- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I'm thinking this might be great for my system. I'm also aware of what would happen if the Secretary of War saw this show up on my doorstep.
Just have a cardboard cut out made of your current system and slide it over... Put the grill over the cut on the box, would never know!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Man this is tempting!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
This may be ebay sold... But no payment yet so pending- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Back on market, still available- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I’m thinking this is a nice upgrade for my near field setup in the office. Currently running a PSW225i wireless.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
absolutely. This would be a KILLER nearfield/small 2 channel sub. The thought of placing it in my office with the Cubs crossed my mind but I like my current simplicity a little to much... minimal wires- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
All right Trey. PM coming!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Now I have to watch out for the secretary of war!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Sold!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
You better get her a new coffee maker ASAP addict!!!!Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
And congrats on the sale!Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Thanks brother! I see "Operation SVS" underway. Planning stages in processBasement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Welcome to the svs family -
Congrats man, and thanks. For what ? Saving my own arse from my secretary of war because I was almost ready to jump on this.HT SYSTEM-
lsi 9's -
Lol. I know a guy who's married to a woman from Korea he calls her the Red Army
I know another guy who calls his wife the House Ways and Means Committee
I know a guy who calls his EX see u next tuesday
Congrats!Yamaha RX-A2070, Musical Fidelity M6si integrated amp, Benchmark Dac1, Bluesound NODE 2i, Audiolab 6000CDT CD Transport, Parasound Zphono USB Phono Preamp, Fluance RT85, Ortofon 2M Bronze, Polk L600's, L400, L900's, RC80i's, SVS 3000 Micro, Audioquest Interconnects and Digital Cables, Nordost Silver Shadow Digital Cable, Cullen Gold and Crossover Series Power Cables, Douglas Connection Alpha 12AWG OCC Speaker Cables, Douglas Connection Alpha Analog Interconnect Cables, Douglas Connection Alpha 11 OCC Custom Power Cable, Signal Power Cable, Furman PL-8C 15 Power Conditioner, Sony 65" 900F, Sony UBP-X700, Fios, Apple TV 4K, Audioquest Chocolate HDMI Cables.
Working from home today (operation SVS underway ) Sub just got delivered, safely. Looking good! Thanks Jim!
Who the heck is Jim? I'm so confused!?!Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Trey Jim maybe?
I'm glad it's staying in the family!Most people just listen to music and watch movies. I EXPERIENCE them. -
Hmmm. Shipping label says James. Colleague of Trey?Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
