SVS PB-2000 (ported subs for music)
dr1978
dr1978 Posts: 424
I'm ready to take the plunge on a subwoofer upgrade. After looking around at the used market for a while I think I just want to go new. I'm going to try an SVS and I'm leaning towards the PB-2000. I do think it's the best choice for the whole family, but considering that I personally use the system for music much more than movies, I've been going back and forth between this and the sealed version, SB-2000.
With the understanding that the same sub can sound different in other systems and especially rooms...has anyone purchased a ported sub and been disappointed in the sound it produced for music?
I don't think I have the most critical ear, so I'm thinking/hoping that the potential loss of control might not be a deal breaker for me. But then when I read the word "boomy" that makes me a little nervous.
I know that SVS has a great return policy that I could take advantage of if I am not happy with it, but hearing some anecdotes first could be helpful.
Pro-ject 2 Experience SB, OPPO BDP-103, Marantz SR5011, Lounge LCR MKIII, McCormack DNA-HT5, Polk LSiM705, Polk LSiM706C, Polk LSiM702, SVS SB16-Ultra
    pitdogg2 Posts: 26,962
    Check out their outlet store. Good deals can be had and still have a good warranty.
  • dr1978
    dr1978 Posts: 424
    My room size is 12x21 with an 8' ceiling. Based on what I've read that puts me on the border when just strictly looking at square feet.
  • dr1978
    dr1978 Posts: 424
    Thanks for the heads up! Looks like they do have an SB with no damage for $100 off.
  • PSOVLSK
    PSOVLSK Posts: 5,372
    Call SVS. They will give you honest feedback as to which sub will work best in your situation.
  • ken brydson
    ken brydson Posts: 8,988
    PSOVLSK wrote: »
    ^This^ and they won't try to oversell you.
    Clipdat Posts: 13,089
    Rythmik worth a look for music.
  • mrloren
    mrloren Posts: 2,474
    I run my VTF3 with one port open. sounds great on music.
  • sgmsmg
    sgmsmg Posts: 556
    They (SVS) usually have a sale around Black Friday so you may want to wait a bit.
    Pre: Bryston BR20
    Amp: Buckeye NCx500
    Speakers: Polk L200
    Source: Oppo UDP-205, Bryston BDP-3, Bryston BCD-3, Apple TV, Amazon Fire
    Cables: Wireworld Gold Eclipse 7 Speaker, Wireworld Gold Eclipse 7 XLR, AQ Diamond USB/HDMI
    Power: PS Audio P10 Regenerator, AC12, AC10 and AC5 Cables
    Display: Sony XBR65Z9F
    Pre: Anthem AVM90
    Amps: Buckeye NC502
    Speakers: Polk LSiM 707 (FL/FR), Polk LSiM706 (Center), LSiM 703 (SL/SR/SBL/SBR), Polk 900-LS (Atmos)
    Subwoofers: SVS SB16 x 4
    Source: Oppo UDP-205, Apple TV, Amazon Fire
    Cables: AQ Meteor/Rocket 88, AQ Niagara/Sky
    Power: Torus AVR20, Shunyata Denali, Shunyata Delta, Cullen, PangeaAC9SE Cables
    Display: Sony XBR85Z9G
    F1nut Posts: 51,700
    Don't worrry, the SB4000 will rumble the house for HT and rock it for your music.
  • dr1978
    dr1978 Posts: 424
    ...and demolish my bank account!
    But thanks everyone. I'll give SVS a call, feel them out for a Black Friday deal, and do a deeper dive on Rythmik.
  • dr1978
    dr1978 Posts: 424
    Hmm, the ability to manipulate the ports on the HSU VTF3-MK5 is intriguing. $40 off right now, too.
  • mlistens03
    mlistens03 Posts: 2,767
    FWIW, in the past, I've been able to make it sound like a sub is quick by running it with full range towers. The towers will do the initial thud and then the sub will catch up moments later.
    I decided this wasn't a good enough solution for this issue, so I got a replacement sub, a Boston Acoustics PV500. It is ported and is almost as fast as my Velodyne sealed sub. Still using it because it is a bit more musical than the Velodyne.
    I think it is pretty much a toss-up between ported and sealed, well-designed versions of either (and with SVS or Rythmik you are getting a well-designed sub for sure) can be lightning fast.
    Oh, and one more thing; servo corrected subs rock. I've heard one, and it was incredible. I didn't know a fifteen could be that fast. :)
  • mrloren
    The VTF-3 is a very nice sub, good on music and movies. The many settings can get confusing to say the least. I have mine set to, 4" port open, EQ2 and "Q" to 5.5.
    It was a toss up between it and the SVS PB2000, If I had the extra coin it would have been a SB13Ultra.
    I just looked at SVS website. https://www.svsound.com/pages/subwoofers the NSD are back at great prices, Go dual for a grand or less if you have the room. There is also the new 3000 series
    I have yet to hear an HSU or SVS sub the didn't pump out good bass. Can't go wrong with either brand.
  • Emlyn
    Emlyn Posts: 4,640
    If it is only going to be one subwoofer in the system I would go with the PB design. I decided to get dual SB 2000s with my LSIm speakers. That is in a 20 foot by 20 foot room in a home theater system. I have had SVS ported subs before and found them not be as good for music as sealed designs. Dual sealed subs work much better in my situation.
    tonyb Posts: 33,068
    A ported sub will give more low end rumble for HT, sealed subs are generally a tad quicker for music. If you go sealed sub, get the bigger ones or duals.
    That said, I have the SVS SB2000 in a roughly 25 by 25 room, great on music, good on HT too, but it's at it's limits on the HT side in a room that large.
    Ported subs from the better sub makers, will not have that loose lower end like the cheaper subs do when pushed.
  • afterburnt
    afterburnt Posts: 7,892
    I have two pb 2000 and when dialed in the are fine for music my lsim 707's do most of the work though
  • dr1978
    dr1978 Posts: 424
    I'll be doing some measuring at lunch to see if I could make dual SB12's work. Spoke with an SVS rep and he seemed pretty confident that it would provide enough punch to keep the kids excited. Sure, we'll miss out on a bit of the LFE in movies, but what they don't know won't hurt em!
  • mrloren
    Dual SB12 you won't miss much if any LFE. Those will shake nice
  • Milito
    Milito Posts: 2,003
    edited November 2018
    mrloren wrote: »
    Anyone have the NSD and what do you think of it say compared to HSU VTF-2 MK5?
  • mrloren
    Milito wrote: »
    mrloren wrote: »
    HMMM good question. My Friend does have an older SB12NSD, it does very good in his converted spare bedroom to HT. At the current cost I'm sure two PB12NSD will out perform a single VTF3.
    Don't get me wrong, the VTF3-MK5 is a very good sub that rocks.
  • dr1978
    dr1978 Posts: 424
    Welp, that was quicker than expected. Two SB12's will just barely fit, and the wife is on board. I'll be plugging them in on Wednesday!
  • Milito
    Milito Posts: 2,003
    Congrats!
    dr1978 wrote: »
    Dude you're sunk......
    The 5k purse is coming home
  • dr1978
    dr1978 Posts: 424
    I really am waiting for the other shoe to drop, because she flat out encouraged me to look into getting a sub after I (innocently) mentioned that was the next piece I would upgrade.
    But whatever it is, it will be worth it. I'm freaking pumped!
  • afterburnt
    They usually get real nice like that just before they try and kill you. Trust me I know, Lancaster 1998, Glendale 2009, Simi Valley 2012 etc. I survived because I know that "look" ya know when they smile at you and stuff. Take her out for dinner from now on, trust me on this.
  • mrloren
    Or it could be what happened to me, "sure get the Signatures" week later Mother in-law moved in for a year
    tonyb Posts: 33,068
    afterburnt wrote: »
    They usually get real nice like that just before they try and kill you. Trust me I know,.
    LOL, to become old and married is like surviving 3 world wars. One must learn woman speak in order to survive.
  • mrloren
    dr1978 wrote: »
    Well how do you like the sub?
  • dr1978
    dr1978 Posts: 424
    mrloren wrote: »
    dr1978 wrote: »
    They're sounding great! We had some family in town for Thanksgiving and they pulled up just as I was connecting the speakers. I didn't get a chance to calibrate them until just yesterday. I definitely don't have them dialed in yet, but the improvement is very noticeable. I'm glad I went with the closed subs, the kids watched the Incredibles 2 yesterday and that was more than enough for them.
    I will probably have to reach out to SVS though. I ran the MultEQ XT on my SR5011 and it set the subs to -12. The SVS pamphlet said to give them a call if this happens. I just manually set it to -6 in the interim.
  • mrloren
    yeah, Audyssey XT is hard to set the subs. No Idea why Marantz doesn't put XT32 on the SR50XX line.
    Here's an Idea. run Audyssey with one sub. Just do the 3 point test till it sets it at -3db. Then run the 2nd sub till it's -3db. Plug in both subs and run Audyssey 6 point calibration
