Quel amplificateur ???
Bonjour j’aimerais votre avis sur un bon amplificateur à utiliser avec mes hauts parleurs, oui j’utilise 2 sub , je pensais faire l’achat du Yamaha RX-V1083
RTI A9
CSI A6
RTI A1
RTI A5
HTS 12
PSW 125
RTI A9
CSI A6
RTI A1
RTI A5
HTS 12
PSW 125
Best Answers
Ce récepteur serait un bon choix, mais ces grandes enceintes nécessiteront un amplificateur séparé pour obtenir le meilleur son possible.
Parlez vous anglais? Sinon, vous voudrez peut-être utiliser Google Traduction, comme je l'ai fait. -
The A9s really need an external amplifier, not just an AVR, with about 200 watts per channel or more.
The yamaha will sound better than the Onkyo, but still does not have nearly enough power for your speakers.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Bedroom 2.1 Harmon Kardon HK3490; Bluesounds Node N130; Polk RT25i; ACI Titan Subwoofer
Answers
Si Senor.Since we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey
– Kevin Alfred Strom
Idolizing a politician is like believing the stripper REALLY likes you. -
Know i have a Onkyo 757 and i want something better
Witch one should be better for me ??
the yamaha is MUCH better, but you really still need a separate amplifier such as this: https://www.audioadvisor.com/prodinfo.asp?number=PAC2250V2&variation=BLK&gclid=EAIaIQobChMIqvuR3c_P3gIVXZ7ACh1T9gd3EAQYASABEgINc_D_BwELiving Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
So the RX-A2070 is better ?? Because i found the 2070 for 1499$ and the 1083 for 999$
I would get the cheapest yanaha, denon, or marantz that has preouts and use the rest of the budget to buy an external amp.
None of those receivers will properly drive your speakers.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
https://www.youtube.com/watch?v=gvgAyxl9ag8
