Power Cables For Sale (Mostly Pangea)
  • headrott
    headrott Posts: 5,484
    Ok, thanks for checking guys.
    EndersShadow Posts: 17,528
    edited November 2018
    Hermitism wrote: »
    Hermitism wrote: »
    I don't have a screwdriver the right size. My little sunglasses screwdriver is too small, but my smallest "normal" screwdriver is too large. Sorry I couldn't be more helpful.
    Try using a nail file, or a paperclip......... I've used both for my PS Audio cables in a pinch lol......
    I always said you had well kept nails. Paperclip fit, but wouldn't budge it. If it's a threaded pin, it is seriously tight.
    Lol... nope, no ones ever accused me of that one....
    I am however married, so we have like 5 million nail files lol..
  • Hermitism
    Hermitism Posts: 4,204
    I did find a post where Jesse said that Pangea started using removable ground pins. I can't imagine Jesse ever being in the same room with a Pangea cable!
    thsmith wrote: »
    PS Audio PCs have removable ground pins.
    Yes they do and if it is slightly loose it will cause noise, which will drive you nuts for months trying to figure out what the h e l l is wrong. I put Loctite thread locker on mine after that *%&$#!***** episode.
    Pangea has them now as well.
