Favorite Center Channels
Seeburg DDS-1. Two 15" Utah woofers and an Altec horn.Make it Funky!
With line arrays there is no need for a center channel.
I run a pair of cs400is between a pair of 1.2s. This works very well, sounds great and they match pretty well with the 1.2s. I run the 1.2s full range but send the below 80Hz material to the sub. The little fellers can't quite keep up with the big boys on the low end.
Phil -
Phil, are you the kicker for the Cleveland Browns?
