Window Shopping.
Cant take home with me.
Cheers
HTAVR-Pioneer SC99XPA-DR3 Differential Reference AmpPolk R-700Rear- RT150Side- RT150Center-CSi5Sub-Rythmik audio F25Player- Panasonic DP-UB9000Projector- Optoma CinemaX P2Screen- Silver Ticket Products STR Series 6 120"Audio Room 2ch rig.Cary AE-3, Onkyo M-504, Marantz SA8005, Azur 851NWharfedale - Linton, SVS SB12-NSDMinis Forum PC (streamer) and Panamax MX5105Headphone rig;Schiit JOTUNHEIM and different headphones.Samsung 42" flat screen TV.
  • Dabutcher
    Dabutcher Posts: 2,604
    Thanks for sharing. Peace. D
    Tony M Posts: 11,617
    edited November 2018
    I wish they had US dollars on those price tags.
    I remember servicemen in the 60's buying overseas because the exchange rate was so low.
    I like them all but that Denon Integrated looks pretty powerful. I just looked on the web and I was mistaken. I found a similar int. that was a SX11 and it was $5,000.00+. I didn't check it's stats since I can't afford it at all.
    Manual Library / Denon
    Denon PMA-SX1
    Stereo Integrated Amplifier (2014-17)
    add a review
    Specifications
    Power output: 50 watts per channel into 8Ω (stereo)
    Total harmonic distortion: 0.01%
    Input sensitivity: 0.2mV (mic), 2.5mV (MM), 105mV (line)
    Signal to noise ratio: 70dB (MC), 82dB (MM), 105dB (line)
    Output: 0.7V (Pre out)
    Speaker load impedance: 4Ω to 16Ω
    Dimensions: 434 x 181 x 504mm
    Weight: 30.4kg
    Accessories: remote control
    Year: 2014
  • joecoulson
    joecoulson Posts: 4,943
    Nice gear. Love the CD/MD combo
  • verb
    verb Posts: 10,176
    Nice stuff. I understand that the Japanese products run on 100V AC. Is that compatible with our standard?
  • mrloren
    mrloren Posts: 2,474
    Why can't you bring anything back? I see Navy guy's do it all the time. When my niece and her husband came back from Japan they had a ton of nice HT gear.
    pitdogg2 Posts: 27,045
    verb wrote: »
    Maybe need a step down. Do they run 50hz or 60hz cycles? and would that make a difference?
  • verb
    verb Posts: 10,176
    verb wrote: »
    Interesting. Looks like the regions are different in the same country!
    https://www.japan-guide.com/e/e2225.html
    That is strange
  • mrloren
    For video I know there is the NTSC/PAL thing on video. All other electronics I see people bring back here work just fine.
  • Irrenhaus
    Irrenhaus Posts: 1,101
    Another find while window shopping.
    Tear Drop bar 50's to 80's music all in vinyl.
    Simple:
    Choose your drink and you get to pick a song.
    Choose from the library.
    Led Zeppelin All My Love
    And they use a cool setup.
    Cheers
  • joecoulson
    Nice! What a cool spot
