Best speaker setup
Hi!
I'm new here, I would like to choose the best setup for my room.
He has 11 feet x 16 feet, but it is integrated with another room.
I want buy all polk speakers and I believe that the 5.1.2 setup is ok.
2 S20 speakers
1 S35 or S30 (what is better for my room?)
2 Atmos speakers (what use RC80i or v60?)
2 surround speakers (what choose?)
1 sub (what choose? HTS10?)
Thanks for any help.
Regards,
Cristiano
  • FestYboy
    FestYboy Posts: 3,861
    Personally, I'd flip the room 180*. Better front speaker placement can be realised without the windows to hinder it. It also allows more of the larger room n general to view the screen.
    Tony M Posts: 11,673
    What @FestYboy said...100%.
  • mrloren
    mrloren Posts: 2,473
    What AVR are you going to be using?
    V60 over the RC80, vanishing looks a lot better
    S30 for the center, more full sounding if you can fit it.
    Sub look for SVS or HSU, if you can't get them where you are then the HTS is ok.
  • steveinaz
    steveinaz Posts: 19,545
    Anytime you have a couch against a wall, bass is gonna be wonky.
  • Airplay355
    Airplay355 Posts: 4,298
    What's between the plants on the rightmost wall?
  • Hey guys. Thanks for replying. Sorry my delay in answer you, because it was a holiday here in Brazil.
    I personally prefer the other room too, but like in the picture the space is more visible.
    Between the plants it is a wood sideboard.
    The receiver probably will be an Onkyo TX-NR787.
    I will take a look in the SVS and HSU subwoofers, but i'm looking for a good budget woofer.
    Thanks again!
  • FestYboy
    edited November 2018
    I'm not saying trade space for space, I'm saying flip your viewing room area 180 so the couch sits where the tv is in the picture and visa versa.
    Edit for auto correct
  • mrloren
    I agree to flip your room. Reflection's from windows suck, I found it to add brightness to the sound.
    AVR, I would get a Denon, Marantz, Yamaha or even Sony over an Onkyo.
    If you can get either HSU or SVS subs they are a step up from the HTS. I have heard the HTS subs are better than previous Polk subs.
  • Thanks again!
    Now I understood. I will check the possibility to flip the room, the main question is that all instalation (power, network, etc) is in the other wall.
    About the AVR I will look for another brand, thanks by the advise.
