Melos SHA-Gold Headphone Amp On The Bench
SCompRacer
SCompRacer Posts: 9,121
edited October 2018 in DIY, Mods & Tweaks
While recovering from some minor surgery, I took this project on for a good friend. A Melos SHA-Gold Headphone amp and pre amp (1996). It has some issues. There are plenty of reviews and opinions about the SHA-Gold if you are not familiar with it.
Snagged these from the web to show assembled.
While it powered up, the remote did not work. The remote is important for volume control but essential for the un-mute function and balance control. There is no mute/un-mute switch or balance knob on front panel. When you power up, it is in mute and the remote is the only way to un-mute it. The balance pot is behind the front panel meter.
A cell phone verified the remote IR transmitting. I had 5v power to the IR receiver, and voltage dropped when remote buttons pressed. I got a remote signal to IC chip, but no command action took place. Fortunately, a disassembly and cleaning on the remote buttons repaired that. The buttons that contact the remote board are a stippled black metal. After remove corrosion with rag and cleaner, life was good. Note black stuff on rag. My guess is the remote sent a corrupted signal.
While the mute/un-mute worked now, the remote volume and balance controls did not. The motors spun but the pots did not move. I disassembled them and found the thin plastic on one end of the gears that acted as spacer had broken, allowing the gears to drop out of alignment.
The volume control was easy to remove, but the balance control was soldered to the board. I drilled a robust aerosol straw to press fit on the gear shafts and cut to length for a spacer. Now the gears stay in alignment and I have volume and balance control. The meter on front panel indicates channel balance.
The volume of the Melos Gold is photo optical. An incandescent bulb illuminates below photo cells to vary resistance and change the volume. The idea here was to eliminate any mechanical wiper noise or inconsistent wiper pressure/inaccuracy. There are folks that can’t/won’t repair it. The owner prefers to keep it as designed but working. A popular remote volume board used to convert these runs $300.
The volume bulb is actually a fuse bulb originally made by BUSS. It illuminates under two photocells, one for right and one for left channel volume. The original bulb was blown. Bright is minimum volume, dim is max volume.
There were no specs on the bulb or published that I could find. After measuring voltage and current, I purchased a few 6 volt fuse bulbs in various amperages. So far the 6v .25 amp looks the best based on video I watched of one in action.
More problems lurk as the scope shows. Those sine waves connected to the outputs don’t look like what is coming out of the signal generator. More to come.
Here is a good shot (snagged from web) of the volume control board with balance control at left. The remote pictured is not the one we have.
Post edited by SCompRacer on
    EndersShadow Posts: 17,719
    Rich, as always your work is top shelf!
    pitdogg2 Posts: 27,228
    You need a hobby Rich....
    Nice ;)
  • kharp1
    kharp1 Posts: 3,453
    Ah, heck, anybody could do it the easy way.
    I admire your troubleshooting skills.
  • machone
    machone Posts: 1,562
    Nice work!
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • schwarcw
    schwarcw Posts: 7,358
    Rock on Rockman! Nice work.
    Carl
  • delkal
    delkal Posts: 764
    For its original price I wouldn't have expected that many different things to break in 12 years!
    What happened to it? In the basement during a recent hurricane?
  • schwarcw
    edited October 2018
    How about 22 years :D ? This Melos model has a reputation for sounding great but has reliability issues.
    Carl
  • delkal
    delkal Posts: 764
    schwarcw wrote: »
    Sorry but I ran out of fingers! You are correct.
  • agfrost
    agfrost Posts: 2,474
    If you knock it off the bench, you can drive over to Holm Audio to pick up their used one as a replacement... :D
    Jay
    edited June 2019
    Shame, bad Richee….this has been on the back burner too long. Still short a guy at work, too much OT, but enough excuses. Finally it lives, both channels output what they are supposed to.
    This video on you tube was a life saver. This fellow, M Caldeira, removed components and drew schematics. He explained the issues he ran into which helped solve the problem.
    https://youtu.be/R0AXvMcoWSg
    Sorry it took so long Carl!
  • schwarcw
    Looking good Richee!
    Carl
  • Hello by any chance do you have remote for this unit?
