Connecting Computer (VGA) to 65 inch display (HDMI) sound not required
For work, I have to supply a wall mounted 65 inch display, and connect it to a computer that only has VGA out (1920x1080).
Any help selecting a converter would be appreciated.
Thank you
Russ
Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
  • FestYboyFestYboy Posts: 3,437
    In line converters are all over the net. Some are cables, others are stubby adapters. Just keep in mind that most ar one way in the wrong direction, so look for an analog cable without a box.
  • Mikey081057Mikey081057 Posts: 6,112
    edited October 2018
    Chromecast if you have wireless ethernet
    https://store.google.com/us/product/chromecast
    HT:Polk LSiM 706 LSiM 705's VR3 LSiM 703's LSiM 702's| Marantz AV7704 | Sunfire TGA-7401 | Oppo UDP 203 | Sony PS4 Pro| Directv Genie HD DVR | Samsung 75" Q8 QLED | SVS PB13 Ultra | MIT EXP 2's (Fronts & Center)
    ManCave: Parasound Halo A21 | Parsound Halo A52+ | Marantz AV7002 AV PrePro | Usher Dancer Mini-x DMD's | Usher BE-616 Center | SVS Ultra Surrounds | SVS SB4000 Sub |Oppo UDP 203 | MIT Shotgun S3's | PSAudio Stellar GCD | Music Hall MMF 5.3se TT w/ Soundsmith Carmen | Mytek Brooklyn DAC+ | Lumin U1 Mini | HP Elite Slice PC | ROON'd for life | Samsung 50" SUHD TV | Sony PS4
    Patio Polk Atrium 8's | Yamaha R-N303BL |
    Office Bluesound Node | Polk SDA SRS 2.3 | Marantz 2385 |
    Bedroom Peactree Nova 125SE | Focal 905's | Chromecast Audio | SVS SB2000 Sub
    Garage Yamaha R-N303BL | Polk Monitor 5B's
    Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | 2 Parasound A23's | Marantz 2252B
  • DSkipDSkip Posts: 15,591
    Is this a laptop or desktop?
    audiothesis.com/
    Speakers: Harbeth: 30.2, SHL5+; Usher: Be-10, T-515; Rosso Fiorentino: Elba, Pienza, Certaldo, Fiesole, Volterra; Polk: T50, Signature S15, RTA 15tl, RTi12; Sonner Audio Allegro Unum, Legato Unum, Legato Semis, Legato Duo; Emerald Physics CS-2.8; Klipsch KLF-20
    Preamps: Shuguang S200MK, Dayens Ampino, Parasound P5
    Amps: Shuguang S845MK, Dayens Ampino Monoblocks, Parasound A23
    Integrateds: Triode Corporation TRV-88SER, MastersounD: BoX, Dueventi, Compact 845, Evolution 845; North Star Design Blue Diamond
    Sources: AURALiC Aries, Denon HEOS Link, North Star Design: Magnifico, Supremo, Incanto, Intenso, Venti
    Cabling: Wireworld
    TV: Sony XBR-75X940C
  • hoosier21hoosier21 Posts: 4,393
    FestYboy - I have seen so many choices, hoping for recommendation
    Mikey081057 - wireless in not an option, Utility control room installation
    DSkip - Desktop, SEL 3355 computer
    To ask it anotherway, anyone know of a 65inch display that supports 1920x1080 with VGA input?
    You cannot add/swap a video card with HDMI?
  • Viking64Viking64 Posts: 3,784
    Some displays that size are really picky about resolution. They may have only a few native screen sizes that they will recognize and if your computer video software doesn't output the EXACT number of pixels, you would get no image.
    If have tried a few cheap solutions with not so good results.They tend to need to be unplugged and plugged back in to facilitate an HDMI handshake each time. I can't name any particular brand names because they are somewhere in a box in storage where they belong.
    This is where I was going. Adding a video card will give you HDMI and allow your computer to operate smoother since the CPU will be less taxed.
    audiothesis.com/
    Cabling: Wireworld
    Thanks for the comments, I can not add a video card. I will figure something out.
  • mdaudioguymdaudioguy Posts: 4,893
    Search "VGA to HDMI" on Amazon. Lots of choices under $20. Go with the most/best reviews.
    7.1 - polk RTi10 x 3 (LCR) : FXi3 x 2 : RTi4 x 4 : Sunfire SDS-12 : Yamaha Aventage RX-A2040 : Adcom GFA-7500 : Squeezebox Touch : DIRECTV : Roku SE : Panasonic PT-AX200U PJ @ 120"
    5.1 - Definitive Technology ProMonitor 800 x 4 : ProCenter 1000 : Klipsch Sub-10 : Pioneer Elite SC-91: DIRECTV : LG OLED55B6P : Roku Premiere+
    Garage Duty - polk Monitor 10s : Pioneer A-717 Integrated Amp : Squeezebox Classic
    That's going to be your best bet then.
    audiothesis.com/
    Cabling: Wireworld
    I ended up buying a true 65 inch monitor with VGA input, thanks for your time guys.
    I was under the impression that the tv/monitor was already in place. Your purchase fixes everything.
Howdy, Stranger!
