Best KT88 tubes?
I'm going to be purchasing a Quad of KT88 tubes and I have NEVER owned an amp that used 6550's or 88's. Looking for advidlce from someone who has experience with this particular tube.
The difference between genius and stupidity is; genius has its limits.” -Albert Einstein
Sony Playstation 3 for CD and Streaming
Thorens TD320
Modified Carver C-1
Carver TFM 42 and 45 Amplifiers
Polk RTA15TL Speakers w/Decato mods
White Lightning Moonshine DIY Speaker Cables and Interconnects
  • [Deleted User]
    [Deleted User] Posts: 7,598
    edited October 2018
    Original Gold Lion/Genelex KT88
    heiney9 Posts: 25,492
    edited October 2018
    Check with Jim McShane. Have a look at his website, he makes solid recommendations on the new production tubes. I don't sue KT88's so I can't say based on experience.
    nooshinjohn Posts: 25,986
    heiney9 wrote: »
    Did not know there was a field of law specializing in this area. I wonder if KT120's and other tubes can be sued. :p;)
    I use KT-120's and love them. I find they have a little more punch in the bass department and more extension up top than do the KT-88's. If your amp can run 88's then it should be able to do the 120's without difficulty, but check with the company that built the amp to be sure...
    What will you use them in?
  • trav0810
    trav0810 Posts: 1,056
    The amp can run either. It actually comes with 120's, but I have generally found that the lower the wattage of the tube, the more I like it's sound, so I was going to drop down to 88's
    It's basically the Carver Crimson 275
    Thorens TD320
    Modified Carver C-1
  • Mikey081057
    Mikey081057 Posts: 7,127
    Shuguang Treasures
    Garage | Polk Monitor 5B's
  • kharp1
    kharp1 Posts: 3,453
    Shuguang Treasures
    If you're going with new production tubes then I think Shuguang Treasures are probably best for the money.
  • stretchl
    stretchl Posts: 1,334
    Shuguang Treasures
    What he said.
    - Isaac Asimov
    Hi-Fi
    Cabling by Groneberg
    Visuals
  • dhart86
    dhart86 Posts: 1,594
    kharp1 wrote: »
    Shuguang Treasures
    What they ^^^said
    Main Rig:
    Antipodes DX > Roon > PS Audio Directstream Jr.>deHavilland Ultraverve 3 >Belles Reference 150a >Harbeth C7 ES3
    Second Rig:
    Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded)
