My new M6 spikes...or something
    F1nut Posts: 51,959
    jdjohn wrote: »
    Those padded screw in feet are worthless.
    Wrong...they are worth at least $10 drop-shipped from China.
    Spikes couple, those decouple.
    Wrong again. Spikes couple themselves to speaker cabinets, but they decouple themselves from flooring, with only the smallest point of a cone touching the floor.
    Coupling involves solidifying a connection between two objects, whereas decoupling minimizes the connection.
    WAAAAAAAAAAAAAAAAAA you're clueless.
  • jdjohn
    jdjohn Posts: 3,380
    Careful, Jesse...the insinuation is that only your perspective is pertinent. Please explain how the tiny point of a cone barely touching a point of contact is considered 'coupling'.
    F1nut Posts: 51,959
    Push your speaker with your current glides on and it will slide easily because it's not coupled to the floor. Try that with spikes on and it won't slide because it's coupled.
  • jdjohn
    jdjohn Posts: 3,380
    Push hard enough, and it will still slide...no matter what. 'Coupled' involves a mechanical attachment, not just gravity as you suggest.
    A protective disk (via gravity) is all that we can hope for with spikes. In the end, the fine point of a cone touching a protective disk is all that we can hope for.
    F1nut Posts: 51,959
    Sure, you push hard enough with spikes on and they will tear up your floor because they are COUPLED to it. I suggest you consult a few speaker manufacturers since you're having such a hard time understanding the concept.
