Karma: DAC for Mac - HRT Music Streamer HD
Clipdat
Up for your karma consideration is a HRT Music Streamer HD DAC!
I say "DAC for Mac", because I experienced some technical difficulties getting this USB powered DAC to work correctly with the various PCs I tried it with. It seems to be very temperamental about it's USB connection, and on the PCs I tried it with, I experienced dropouts that manifested as static clicks and pops over the music. I wasn't able to reliably get it working without those dropouts, but I tested it on a Mac Mini and it worked flawlessly.
So, if you have a Mac and are looking to try out a very nice DAC go ahead and enter the karma giveaway. If you have a PC I suppose you can enter as well, but just be warned that I wasn't able to get it functioning correctly on the 3 different PCs I tried (Windows 7, Windows 10, and Daphile Linux). So, I'd much rather it go to someone who uses/owns a Mac as their source, so that I know they would be able to get satisfaction from it's flawless operation.
It's a great sounding DAC with excellent musicality and timing, and a punchy engaging sound. Plus it has balanced outputs, so it would be perfect for a set of powered monitors.
Enter by picking a number 1-100 and the drawing will happen next weekend.
Nice Karma! Not it but awesome for someone !
Fabulous Karma Drew! In with 77 please.Audio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
HT: Samsung QN90B * Marantz NR1510 * Panasonic DMP-BDT220 * Roku Ultra LT * APC H10 -
In with 48 please.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
Not in but awesome Karma!Just a dude doing dude-ly things
"Audiophiles are the male equivalent of cat ladies." - Audiokarma Member -
Any way this would work with an iPad? Great Karma.
Love yours, DMIT Magnum MH-750, Monster HTS 5100MKII, Sony 77" Class - A80CJ Series - 4K UHD OLED,PS4, Def Tech 15” sub,LSIM 706c, Sunfire Signature Grand 425 x 4,Parasound hca 120, LSiM 702 x 4, Oppo 103D, SDA SRS 1.2, Pioneer Elite SC63 , Pioneer Elite BDP-05 “Why did you get married if you wanted big speakers?” -
In with 66"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
In with 25 please, nice Karma! I’ll find a way to make it work with my iPad.
Very nice, not in though.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Great timing on this, need one to replace a Dragonfly that just bit the dust. In with my age, 41
Nice Karma Drew!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
This is VERY nice karma. I really liked my HRT music streamer II+ and my HRT micro streamer. Really good sound for the money. I am good on DACs and I traded in my MacBook Air otherwise I would join in on the fun.
Good luck everyone!Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Bedroom 2.1Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer -
Love yours, D
No idea, but I think you need one of these in order to try it:
Love yours, D
I am really unsure if it will. There are only a few that are designed to, the audioquest dragonfly and the ifi Nano iDSD are the only two that I know for sure. I was under the impression that ONLY these would work with iOS devices. But then I plugged my iPhone using the adapter @Clipdat listed to to my def tech incline powered speakers with built in USB DAC, and it worked! So it might be worth a try...but you will definitely need the $30 adapter...which you also need for the aforementioned DACs.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Not sure, mainly because it pulls the power from the device, so even if it does work, its gonna drain your battery faster (which is one thing they tweaked with the new Dragonfly versions)."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
EndersShadow wrote: »Not sure, mainly because it pulls the power from the device, so even if it does work, its gonna drain your battery faster (which is one thing they tweaked with the new Dragonfly versions).
That is a good point Dan. Plugged into powered monitors, power obviously isn’t a problem. And I only tested it briefly...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Not in but nice karma.
Attn: Mac users, last day to get your entries in.
Do you think it would work with the iTunes program on Windows 10?
mlistens03 wrote: »Do you think it would work with the iTunes program on Windows 10?
Not without incredibly disrupting dropouts that manifest themselves as loud static clicks heard over the music. Like I said, I tried it with three different PCs and each one made these occasional static clicks/pops that really detract from the listening experience. -
Ok. Still in, worst case scenario I’ll give it to my Dad for his Mac. -
Alrighty then!
By the way, I was music shopping yesterday at Amoeba and Rasputin's in Berkeley, and Rasputin's had a copy of Rubber Soul on vinyl being displayed and I thought of you. I believe the price tag said $30. -
Is the drawing next weekend? Oops did I just bump this thread?Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Sorry for the late drawing, it'll happen right now!
Looks like @halo is the lucky winner. Congrats Victor!
Whoa! Thanks Drew! I’m really looking forward to using this with my MacAudio: Polk S15 * Polk S35 * Polk S10 * SVS SB-1000 Pro
Congrats!
