Question on a flooring installation
I’m getting ready to install a LVP floor on my enclosed patio which has a concrete floor and brick walls. I’m still trying to decide how to cover the expansion gap around the perimeter. I’m leaning towards gluing 3/4 inch quarter round to the brick. Anybody else hav a better idea?
HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
BR - Yamaha CR800/Polk monitor 5
  • mrbiron
    mrbiron Posts: 5,721
    No better ideas.
    Base or 1/4 round....go for it.
  • verb
    verb Posts: 10,176
    Another possibility:
  • verb
    verb Posts: 10,176
  • Emlyn
    Emlyn Posts: 4,708
    I haven't used LVP before, but have used Pergo and similar. Is there really a need for an expansion gap if LVP flooring is laid over concrete? Or does it expand and contract with different humidity levels?
    Leaving a gap and putting baseboard or molding over it seems like it is the quickest way to cover gaps and avoids possibly wasting flooring through re-cuts.
  • FestYboy
    FestYboy Posts: 3,861
    I still say back cut the brick... Won't need alot of expansion if the LVP is thermally connected to the concrete (no vapor barrier or insulation). The concrete should be relatively stable thermally speaking so the change in temp throughout the year should be less than 20 degrees. The LVP will move the most length wise, so plan accordingly.
