Adcom GFA-7400 - pop sound
dricosr
I just got an used GFA-7400 on ebay on a very good condition almost like new. There is a noticable popping sound when powering up.
The amp is connected thru a 12v trigger cable to a Yamaha RX-A830 receiver. The amp is powering my front stage and the receiver the in-ceiling front and rear surrounds. When powering down there a minor click sound on sequence by each channel.
I tested manually powering the amp 30 seconds after the pre-amp and still can hear the ‘pop’. I have lowered the starting sound level on the pre-amp and the pop level didn’t change.
Should I be concerned? I have read conflicting views on this topic. Thanks!
- Front LR RTIA5
- Center CSIA4 and TCI80
- Presence/Height LR TCI80
- Rear LR RCI80
- Subwoofers 2 PSW111
- AVR Yamaha RX-A830, amp Adcom GFA-7400
Patio: Atrium 4 and Sonos Connect amp
- Rear LR RCI80
I think a on/off thump for most electronics is normal, although I’m not familiar with the Adcom offerings. A lot of amplifiers are designed to keep the from happening. The older GFA models weren’t, and often when you would power them down you would hear a thumping sound several times in a row.
Long story short, it is normal AFAIK. Someone more familiar with this amp will be able to give you a better answer, but I know the older models popped, so why shouldn’t the newer ones? -
Thanks for the reply. Let’s hope is normal then. I don’t mind the pop as long as doesn’t damage my speakers.- Front LR RTIA5
- Rear LR RCI80
Patio: Atrium 4 and Sonos Connect amp -
My Adcom GFA 545 does the same. I believe it is due to no relay on start up, I wouldn't worry too much.Just a dude doing dude-ly things
"Audiophiles are the male equivalent of cat ladies." - Audiokarma Member -
I agree. I have a GFA 7500. Normal for Adcom start up.Main room- RTiA9 x4, CSiA6, in ceiling Atmos RT-70 x4, SVS PC 4000 x2, Marantz 8805A, OPPO 203, Emotiva DR3 G3, Emotiva XPA-2 G3, Emotiva XPA-5 G3, Emotiva DR2 G3, Sony 85" Bravia 9, Panasonic Plasma VT50, PS Audio Power Port X2, PS Audio AC-5 x8, AQ Rocket 33 Biwire speaker cables, AQ King Cobra XLR IC, Furman PFi20 W/Cullen cable, SoildSteel S4-4 rack, Gik room treatments
Office- Legend L600, in ceiling Polk RC80i, Marantz 7704, OPPO 203, Pioneer Elite PDF-59 CD, PSA Stellar 300, Sony 55" 800B, Gik room treatment
Master BR- Signature ES60, Signature S35 Center, Signature S15 Dolby Height, LSI700 in ceiling, SVS-SB4000, Marantz 5012, Emotiva XPA7 G3, OPPO 203, Pioneer DVL-919 Laser Disc, Sony 80J 55" OLED
Patio- SDI Atrium8 x3, Emotiva A-100 amps x3 -
Thanks all for your input. Glad to hear is nothing to worry.- Front LR RTIA5
- Rear LR RCI80
