OK to use 2 centers as main horizontally?
I can get 2 new Klipsch RP 504c for the same price as their bookshelves. is it OK to use them as main in a 2.1 setup?
    VR3 Posts: 29,440
    Put the tweets together and maybe angle the woofers in a slight v to break up the front baffle
    But yep
  • nhhiep
    nhhiep Posts: 877
    put the tweeters together? what does it mean?
  • rooftop59
    rooftop59 Posts: 8,121
    I messed around with two cs400is years ago (hey wait that sounds kinda dirty) and I didn’t enjoy it. I can’t remember what mains I have at the time, but I think it was the rt7s which are similar: I MUCH preferred the monitors, and I really like the cs400i. I still use one in fact...just my two cents.
    Game Room 5.1.4:
    Bedroom 2.1
    VR3 Posts: 29,440
    Ah I misunderstood, I thought you were saying use bookshelf speakers as a center.
    I wouldn't use a center for mains
    F1nut Posts: 51,789
    nhhiep wrote: »
    Depends who ask or should I say, where you ask. Here I believe you will get the proper advice, no. At AK where some think using Monitor 10's on their sides is ok I suspect they will tell you it's ok to use centers as mains.
  • rooftop59
    Center channels are to voiced to project human voices above everything else, and the drivers are often staggered (each speaker has a different crossover point) to help avoid lobbing effects. This all makes them good center channels, but bad for two channel listening. If you have experienced a good two channel setup, I don’t think you’ll like it. If you’re moving from a Bluetooth speaker or sound bar, you might think it’s great. But I would make sure I could return the speakers in case you don’t like it if you decide to try it...which I wouldn’t recommend.
    Game Room 5.1.4:
    Bedroom 2.1
  • nhhiep
    nhhiep Posts: 877
    this is a 3 ways speaker. more drivers than their bookshelf version rp 600m. I was thinking the soundstage would be wider, fuller sound. no?
    F1nut Posts: 51,789
    No and for the reasons roof stated
  • nhhiep
    nhhiep Posts: 877
    so if these are voiced for human voice and since my setup is 90% karaoke. would my case best if I use center as main?
  • Rich502
    Rich502 Posts: 146
    If you do use the centers as mains, make sure you cross them over and don’t run them full range, even at low volumes, as they are not meant to play much bass.
    F1nut Posts: 51,789
    nhhiep wrote: »
    Get yourself some PA speakers and a pro amp.
  • rooftop59
    nhhiep wrote: »
    Agreed: nothing special needed for karaoke...
    Game Room 5.1.4:
    Bedroom 2.1
  • rooftop59 wrote: »
    nhhiep wrote: »
    Except earplugs....
  • nhhiep
    nhhiep Posts: 877
    I can't get pass the pa speakers weird look. this system is in the living room
    Clipdat Posts: 13,095
    nhhiep wrote: »
    Even these would give you more of what you're after than using a center channel as mains.
    https://www.sweetwater.com/store/detail/ErisE66--presonus-eris-e66-dual-6.5-inch-powered-studio-monitor
    pitdogg2 Posts: 27,064
    rooftop59 wrote: »
    nhhiep wrote: »
    I onced helped a guy carry in a pair of 100k planer speakers for his rig. It was top of the line Macintosh front end. So when i asked to hear them(speakers) he called up to his wife and asked her to audition them for me. Little did i know what was about to accost my ears. I never again asked to listen to those speakers and system.
    I asked why he chose them and he said they were so lifelike, I right then wished they were a less (ok a lot less) lifelike...
    There are better speakers for what you are going to use them for. They may be over driven with voice from karaoke.
    treitz3 Posts: 20,007
    Jerry rig how one wants. No issue and rock on wit'yo'bad self.
    When you want real advice on a real system? Come to us for advice.
    *Disclosure* No offense to those named Jerry*.
    Viking64 Posts: 7,565
    treitz3 wrote: »
    What about Germans?
    Not part of he topic of the thread. Therefore, I cannot comment.
    treitz3 wrote: »
    HAHAHAHAHA
    Hey, why do you always write your name after you post?
    edited September 2018
    To piss off Russ.
    No other reason, really....it drives him Nuckin' Futz.
    treitz3 wrote: »
    To piss off Russ.
    :p He likes to piss. This must be why.
    He gets @lightman1 really cranky when you "warm up" his leg.....
    Or so I've heard B)
  • lightman1
    lightman1 Posts: 10,796
    I have y'alls addresses.....
    VR3 Posts: 29,440
    That explains it...
    - Not Tom
    lightman1 wrote: »
    y'alls
    Is that a contraction for Lucy Ball? I had only heard her referred to as "Lucille" when using her last name. :p
  • lightman1
    Viking64 wrote: »
    lightman1 wrote: »
    y'alls
    Shut up, rOss.
    It's Jim Reynolds, not Ryan Reynolds. :p
    Jem
