Polk MM6 Momo 6.5’s better that Infinity Kappa 6.5?
DabutcherDabutcher Posts: 2,011
edited August 2018 in Car Audio & Electronics
I have a ten year old Tundra with nice factory JBL system in it. Just ordered four Kappa 6.5 ‘s for four doors. A guy has two used MM6’s momo he says we’re never used from when he worked at Panasonic. If I buy the Polks are they a big jump up from Infinity Kappas? Thanks. D
MIT Magnum MH-750, Monster HTS 5100MKII, Mitsubishi rear projection 73, PS4, PSW505 , Sunfire Signature Grand 425 x 4,Parasound hca 120, RTi12, FXiA6, CSiA6, SDA SRS 1.2, Pioneer Elite SC63 , Pioneer Elite BDP-05
“Why did you get married if you wanted big speakers?”
  • DSkipDSkip Posts: 15,900
    I'd take the Polk. They're thick in the midbass but fun and could do better filling your tundra with sound.
    Forgot. If these are the newer MM series they are not meant to be driven with a head unit. Anything under 4 ohms could toast your unit. Something to keep in mind as I don't know why your configuration will be.
  • DabutcherDabutcher Posts: 2,011
    Went with four Polk MM1 6.5’s for the doors. And bought a lot of dynamat for insulating four doors. Peace. D
  • Dabutcher wrote: »
    Coolness !! Would love to hear your thoughts on them after all the break-in and calibration.
Howdy, Stranger!
