Polk MM6 Momo 6.5’s better that Infinity Kappa 6.5?
DabutcherDabutcher Posts: 1,946
edited August 2018 in Car Audio & Electronics
I have a ten year old Tundra with nice factory JBL system in it. Just ordered four Kappa 6.5 ‘s for four doors. A guy has two used MM6’s momo he says we’re never used from when he worked at Panasonic. If I buy the Polks are they a big jump up from Infinity Kappas? Thanks. D
MIT Magnum MH-750, Monster HTS 5100MKII, Mitsubishi rear projection 73, PS4, PSW505 , Sunfire Signature Grand 425 x 4,Parasound hca 120, RTi12, FXiA6, CSiA6, SDA SRS 1.2, Pioneer Elite SC63 , Pioneer Elite BDP-05
“Why did you get married if you wanted big speakers?”
  • DSkipDSkip Posts: 15,591
    I'd take the Polk. They're thick in the midbass but fun and could do better filling your tundra with sound.
    audiothesis.com/
    Speakers: Harbeth: 30.2, SHL5+; Usher: Be-10, T-515; Rosso Fiorentino: Elba, Pienza, Certaldo, Fiesole, Volterra; Polk: T50, Signature S15, RTA 15tl, RTi12; Sonner Audio Allegro Unum, Legato Unum, Legato Semis, Legato Duo; Emerald Physics CS-2.8; Klipsch KLF-20
    Preamps: Shuguang S200MK, Dayens Ampino, Parasound P5
    Amps: Shuguang S845MK, Dayens Ampino Monoblocks, Parasound A23
    Integrateds: Triode Corporation TRV-88SER, MastersounD: BoX, Dueventi, Compact 845, Evolution 845; North Star Design Blue Diamond
    Sources: AURALiC Aries, Denon HEOS Link, North Star Design: Magnifico, Supremo, Incanto, Intenso, Venti
    Cabling: Wireworld
    TV: Sony XBR-75X940C
    Forgot. If these are the newer MM series they are not meant to be driven with a head unit. Anything under 4 ohms could toast your unit. Something to keep in mind as I don't know why your configuration will be.
    audiothesis.com/
    Cabling: Wireworld
  • DabutcherDabutcher Posts: 1,946
    Went with four Polk MM1 6.5’s for the doors. And bought a lot of dynamat for insulating four doors. Peace. D
  • Dabutcher wrote: »
    Coolness !! Would love to hear your thoughts on them after all the break-in and calibration.
Howdy, Stranger!
