RTI grey asthetics
marcpam
marcpam Posts: 228
edited December 2004 in Speakers
On the grey front, that is on the RTI line of speakers. Have any of you guys touched up the front with charcoal grey paint. What is the best touch up paint for this. I have a very small blemish on the front and I don't see why touch up paint wouldn't work. I occasionally take the grills off, so don't tell me to put the grill on and don't worry about it. Any suggestions on what to use for this?
Post edited by marcpam on
  • PolkThug
    PolkThug Posts: 7,532
    Think of it as "character".
  • steveinaz
    steveinaz Posts: 19,545
    Try posting this in "Troubleshooting" maybe Ken will have some suggestions...
  • Whadyasay
    Whadyasay Posts: 300
    If you can match the color, acrylic or automotive paint applied with a very small brush or q-tip should do. just dab it on lightly, and don't drink too much coffee before doing so.
    Or beer, for that matter.
    Polk LSi9 Mains, Polk LSIC Center, Polk RT25i Surrounds, Polk M3II Rear Surround, SVS PB10-ISD Sub, Denon AVR 2809 (as digital pre/pro only), Sony BDP-S350, Oppo DV-981HD, Cambridge Audio Azur 540C (CD), Marantz MM9000 5-ch amp, Outlaw ICBM, Panasonic th-42PX85u HDTV, Behringer BFD Pro, Monster Power HTS 2600 Conditioner
  • Airplay355
    Airplay355 Posts: 4,298
    try taking the grille do a home depot, i remember there being some grey on the top of the grille. im not sure if they could give u a small amount of paint but they should atleast be able to give u the numbers for the color
