Tidal hifi streaming
  • ClipdatClipdat Posts: 6,216
    edited August 2018
    As far as I could tell, no. You can tell it to generate playlists based off a certain artist, but it was always the same playlist per artist, in my experience. I wish that it had a radio feature like Pandora.
    • "Electronic music is human sound adapting to indulge technology, and for some, it feels like the signature sound of energy. New and abstract sounds over hypnotic rhythms can conjure vast soundscapes for escape, pleasure, and transcendence."
  • txcoastal1txcoastal1 Posts: 10,262
    You can pic genres, if that’s what you are asking
  • steveinazsteveinaz Posts: 18,894
    txcoastal1 wrote: »
    Will it play a genre of misc songs, or do you have to pick and chose each song?
    Source: Bluesound Node 2i | Preamp/DAC: PS Audio Stellar Gain Cell | Power Amp: Parasound Halo A21 | Speakers: PSB Imagine T2 | Cables: Signal Cable Analog 2 XLR; Kimber 8VS Bi-Wire; DH Labs D-75 Dig Coax | AC Power: Panamax M5300-PM
    edited August 2018
    Oddly, I know Pandora is basically stone age, but I love the radio like feature. As an example I created the "Kansas Channel" and it is awesome. It nails the songs I'm looking for in classic rock.
    Funny thing, Pandora "free" sounds way better than XM.
    It will show a list and then you could edit or hit play
    edited August 2018
    So, if I select genre, then Rock, and hit play; it will play a mix of rock songs?
  • Mikey081057Mikey081057 Posts: 6,099
    In addition.... Roon has a feature called Roon Radio that you can select to play a similar genre mix of music after playing an album which is pretty cool.
    HT:Polk LSiM 706 LSiM 705's VR3 LSiM 703's LSiM 702's| Marantz AV7704 | Sunfire TGA-7401 | Oppo UDP 203 | Sony PS4 Pro| Directv Genie HD DVR | Samsung 75" Q8 QLED | SVS PB13 Ultra | MIT EXP 2's (Fronts & Center)
    ManCave: Parasound Halo A21 | Parsound Halo A52+ | Marantz AV7002 AV PrePro | Usher Dancer Mini-x DMD's | Usher BE-616 Center | SVS Ultra Surrounds | SVS SB4000 Sub |Oppo UDP 203 | MIT Shotgun S3's | PSAudio Stellar GCD | Music Hall MMF 5.3se TT w/ Soundsmith Carmen | Mytek Brooklyn DAC+ | Lumin U1 Mini | HP Elite Slice PC | ROON'd for life | Samsung 50" SUHD TV | Sony PS4
    Patio Polk Atrium 8's | Yamaha R-N303BL |
    Office Bluesound Node | Polk SDA SRS 2.3 | Marantz 2385 |
    Bedroom Peactree Nova 125SE | Focal 905's | Chromecast Audio | SVS SB2000 Sub
    Garage Yamaha R-N303BL | Polk Monitor 5B's
    Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | 2 Parasound A23's | Marantz 2252B
    edited August 2018
    So is Roon a music library front-end? Sorry for all the questions, last time I had "software" was during my SQBox days. The Oppo has a built in interface which works with my ipad.
    Yeah that pretty much sums it up... It can also integrate supported networked devices for a whole house (& Backyard B) ) music solution. I don't use my Oppo's for music and would have to check if supported by Roon
    https://roonlabs.com/howroonworks.html
  • DaveHoDaveHo Posts: 2,182
    Pretty sure the 203 & 205 can be used as a Roon endpoint. Not sure about the 103/5.
  • treitz3treitz3 Posts: 12,888
    tonyb wrote: »
    txcoastal1 wrote: »
    ..can do a lot of business on the ground :)
    Yeah, we know. You and Tom have a lot in common it appears. :p :p :D :D
    Yes we do. We both drive ridiculous amounts of miles in a day, working the entire time.
    The Bluesound Node doesn't sound that good to me at all, I know. I have one. BUT, hook it up to a decent DAC and the Quality comes very close to CD quality. The only difference I notice is a little bit of mid-bass suckout. Like someone used an EQ to lower the signal of the mid-bass. Other than that, with the Musical Fidelity Tri-Visat tubed DAC I have it paired with? One would be VERY hard pressed to find any difference between a CD and the Bluesound Node.
    I love Tidal but the MQA has to go through the Node. Sorry but it sounds better through the DAC, so MQA is a waste for me.
    Steve, no it does not. You can create your own "genre" of music though. I have discovered many a new artist using this.
    In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence.
    The best way to enjoy digital music reproduction is to never listen to good analogue reproduction.
    Cool, thanks for the info. I would definitely be running the Node 2 thru my Benchmark DAC2.
    Get the free Tidal trial, toss it aside if you don't like it.
  • DSkipDSkip Posts: 15,551
    Streaming devices to consider but not limited to include AURALiC, Aurender, Blue Sound, Innuos, and Lumin.
    audiothesis.com/
    Speakers: Harbeth: 30.2, SHL5+; Usher: Be-10, T-515; Rosso Fiorentino: Elba, Pienza, Certaldo, Fiesole, Volterra; Polk: T50, Signature S15, RTA 15tl, RTi12; Sonner Audio Allegro Unum, Legato Unum, Legato Semis, Legato Duo; Emerald Physics CS-2.8; Klipsch KLF-20
    Preamps: Shuguang S200MK, Dayens Ampino, Parasound P5
    Amps: Shuguang S845MK, Dayens Ampino Monoblocks, Parasound A23
    Integrateds: Triode Corporation TRV-88SER, MastersounD: BoX, Dueventi, Compact 845, Evolution 845; North Star Design Blue Diamond
    Sources: AURALiC Aries, Denon HEOS Link, North Star Design: Magnifico, Supremo, Incanto, Intenso, Venti
    Cabling: Wireworld
    TV: Sony XBR-75X940C
Howdy, Stranger!
