Bits are bits? Why a USB cable might matter
Joey_V
Joey_V Posts: 8,603
edited August 2018 in Going Digital
Apparently when your computer sends data to another storage device or unit, there is a check sum at the receiving unit and if a data set is bad then the transmission is retried.
Hence a bad usb cable only causes delay of transfer of data or bits.
In audio, the signal is tried once. So in theory a corrupted audio data set will not be corrected. Hence a good usb cable is needed.
https://www.edn.com/design/consumer/4376143/Fundamentals-of-USB-Audio
  • machone
    machone Posts: 1,561
    Joey_V wrote: »
    And clean power helps to prevent these packet errors.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • Interesting article and informative which spurred me to do a little extra research.
    In looking at the different transfer mechanisms, you would think that any device supporting USB music playback would not use bulk transfer. It would make sense then why a good USB cable would be needed if you weren't validating the data using checksums and resending data.
    I wanted to see if I could find out about my OPPO UDP-203 and see what transfer methods it's USB input used/supported. In looking at the OPPO UDP-203 manual, it states specifically:
    This unit supports “USB Mass Storage Class Bulk-Only Transport” devices only. Most USB
    thumbs drives, portable hard disk drives and card readers conform to this device class. Other
    USB devices such as MP3 players, digital cameras, and mobile phones may not be
    compatible.
    So this device only supports Bulk Transfer. That leads me to conclude that it is somehow storing the data in memory and buffering to make sure bit for bit transfer is complete. This is not the mechanism you would think would be used for music playback such as Isochronous (transfers are used to transfer data in real-time between host and device).
    So while I see that a USB cable might matter in some instances like Isochronous, it doesn't appear so in this case with the OPPO. It would be interesting to see what devices support USB and for what transfer mechanisms. That might lead someone to determine if buying a higher end USB cable is worth it or not.
    Speakers
    Polk 5jr+
    Polk SDA 2B
    Polk SDS 3.1TL
    Equipment
    Yamaha RX-V3800 Receiver
    Analog Sources: Sony TC-K890ES Cassette, Nakamichi DR-1 Cassette, Technics SL-7 Turntable
  • rpf65
    rpf65 Posts: 2,127
    If everything in the chain mattered, one would have to assume the lowly USB cable would matter.
    I personally feel that there was a noticeable difference when I went to a higher quality HDMI cable, and that is a purely digital transfer, a lot more than USB, but still digital. I don’t know why, could simply be better termination, or any number of simple things, but there was an improvement.
    I think the same would apply to a USB cable.
    It seems the laws of diminishing returns returns happened rather quickly when testing HDMI cables. I would assume that since USB is utilized for substantially less data transfer than HDMI, that diminishing returns would be noticed more quickly.
    With that said, if I were to purchase a USB cable, I would be much more comfortable spending the extra money on a substantially more expensive USB cable from a quality manufacturer than the “it’s just as good, besides it’s only ones and zeros being sent so it doesn’t matter” manufacturer.
    pitdogg2 Posts: 27,153
    The biggest thing in USB cables recently is putting the power wire in its own jacket outside of the data cable. Personally I think that was a step in the right direction to knock down the noise that historically was the biggest complaint with USB cables.
    IMHO
    mhardy6647 Posts: 35,137
    ... even though the power line in USB is DC?
    gudnoyez Posts: 8,169
    This Wireworld Starlight 7 made a difference for me.
