cable tv split, in thoery seems like it will work
Willow
I have my tv hooked up to dig cable, the prob as many as you know I can only watch what I record. My thoughs are I have a 2 VRC lying around. My plan:
after the powerbar/filter, I split the cable ont to cable box and one to the second VCR then to the TV using coax (it's a 2head with no video out) would I be able to record a cable tv show on the 2 head and watch tv through dig cable ?
thanks JF
thanks JF
Post edited by Willow on
It will work up to channels 100 or 125 probably.
Sweet thanks thats what I thought and it would be in the channels under 100 :cool:
Weird, I answered another thread, and it posted here -- deleted what I wrote.
Yeah I do this at home as well... actually have it split to digital cable, VCR, and a TV tuner card on my PC. YOu won't pick up the digital channels on your VCR, as mentioned above.
Just make sure you get a good splitter. I never thought it mattered, but it definitely does. If you use a crappy one half your channels will just decide to come in fuzzy, and your digital channels will crap out on your way more often than they usually would.If you will it, dude, it is no dream. -
Im glad to hear other people have done something like this. I will use an AR splitter.
As a side note, this is also the way to make your PIP work with digital cable if your TV is so equipped."Sure, everything looks bad if you remember it!"
Thanks and hey long time no see!!!
I hook everything up works.....go to use the newer VCR 4head sony then I hear a weird noise and it starts spitting.......POS...now I have to go buy a new 4 head tonight...thank god they are cheap...toshiba for 100$cad :mad: :mad: :mad:
i have a q or too about cable can i combine the sigonal from a ota antina with cabble like they do it with sat tv? i just got a hi def tv and want to get everything i casn out of it.
I don't think a cable box will let you do that, but it's likely your tv has two rf (cable) inputs, just connect your antenna to the second one.Larry
