Flush mount SDA SRS 2
CH46E
CH46E Posts: 3,595
edited August 2018 in Vintage Speakers
SDA SRS 2
The guy who traded me acoustic room treatments with install (Owens Corrning 703) had asked if it would be ok to flush mount them into a wall. They are going into his recording studio for wow factor.
I told him i would ask for him. There would be no toe in of course, i explained and showed him the manual for thier set up.
I did tell him that you dont want a bunch of stuff between them.
BTW: my system sounds so much better. Cant wait to really sit down and listen.
Best Answers
  • FestYboy
    FestYboy Posts: 3,861
    Answer ✓
    They may get rather boomy... Distance to wall is critical to balancing the bass output.
    nooshinjohn Posts: 26,001
    Answer ✓
    They need to come forward at least four inches from anything that may be set between them, and should not be enclosed.
    F1nut Posts: 52,005
    Answer ✓
    CH46E wrote: »
    He said they would be surrounded by bass traps.
    Won't make a difference, they are not a speaker designed to be in a hole.
Answers
