Parasound vs Marantz power amp
joecoulson
joecoulson Posts: 4,943
So I am looking to drive the 705’s with a little cleaner juice. I do not have a huge budget and don’t really need more than 150w pc of clean power based on the rest of my system. I do want a new amp (or refurb) and not an older one.
I have it nailed down to two contenders so far
Marantz mm7025 at 140wpc
And
Parasound 2125 v1 (b stock from safe and sound hq)
Which one would be a better fit for the 705’s with a mix of sources -HT, CD, LP’s etc?
  • joecoulson
    Sorry. 2125 v2 brand new.
    Vs the Marantz new
  • motorhead43026
    motorhead43026 Posts: 4,009
    edited July 2018
    Not a fan of the 2125 sound at all. To me it is too cold and just a touch on the bright side. The Marantz should be just the opposite. Although I have not heard this 7025, I do own Marantz equipment and warmth seems to be a signature trait.
    – Kevin Alfred Strom
  • joecoulson
    Ok. So I went quite sideways from my original choices.
    My local dealer had Linn LK240 monoblocks on consignment for a client. So I got them! Came with set of Linn interconnects and all I can say is what an improvement over my Marantz AV (of course)
    The 705’s are singing
    Thanks for the feedback Polk community. All one of you...;)
  • joecoulson
    Thank You sir!
    You approve of the vintage choice?
  • joecoulson
    Fair enough and yes they do! Thanks man.
