Interesting read.....
heiney9
heiney9 Posts: 25,492
edited July 2018 in The Clubhouse
    Clipdat Posts: 13,100
    Pretty cool. I like that their stuff is assembled in house.
  • dromunds
    dromunds Posts: 10,136
    Interesting, indeed. Thanks for sharing
  • lightman1
    lightman1 Posts: 10,797
    I wouldn't trust Nelson Pass to sort my garbage.....
    VR3 Posts: 29,527
    One of the best amps I've heard
    txcoastal1 Posts: 13,519
    Oooooh how I have sellers remorse of my past Threshold/Pass amps
    Brock TFS
    txcoastal1 wrote: »
    Brock TFS
    I could add more fuel to the fire. This will be my next amp.
    https://theaudiobeatnik.com/pass-labs-xa25-pure-class-power-amp-hpa-1-preamp/
    Same writer as the tour article.
    lightman1 wrote: »
    Would you trust me to sort your garbage?
  • WagnerRC
    WagnerRC Posts: 2,209
    Thanks for sharing. Top shelf company for sure with superior customer support.
    pitdogg2 Posts: 27,220
    The Pass Labs room at Axpona was a joy to check out. They had all the their amps broke down in sections. The guys were a complete joy to talk to and really got into the gear and knew other manufactures gear as well as their own. Made for some interesting conversation.
    Thanks Brock
  • lightman1
    heiney9 wrote: »
    lightman1 wrote: »
    Sure. Come on over.... It's mostly bottles and beard trimmings. Easy peasy.....
    mhardy6647 Posts: 35,198
    edited July 2018
    lightman1 wrote: »
    heiney9 wrote: »
    lightman1 wrote: »
    You trim that thing?!
    Jeepers, if you didn't, you'd look like Cousin Itt.
    Well -- a kinda tall Cousin Itt, I suppose.
    On the hunt for a set of speakers
    F1nut Posts: 51,941
    Nelson Pass is a hack.
  • BlueFox
    BlueFox Posts: 15,250
    That's the truth. Plus he is a Californian.
    nooshinjohn Posts: 25,983
    edited July 2018
    Nelson Pass is a hack... :p
  • warren
    warren Posts: 756
    When I grow up and get big I’m gonna....
    Some final words,
    "If you keep banging your head against the wall,
    you're going to have headaches."
    Warren
  • lightman1
    I wouldn't trust Nelson Pass to plug in a drop cord.
    lightman1 wrote: »
    This coming from a guy that can't screw in a friggin light bulb, and uses a butter knife to fix a toaster while its still toasting the bread.
  • oldrocker
    oldrocker Posts: 2,590
    Hey, back off on Russ...
    Is a good guy, didn't soil the bushes but did kinda piss on my shoe.
    Which he apologized for.... :o
  • lightman1
    lightman1 wrote: »
    I just change out the whole fixture to get my point across and a knife in the toaster is better than coffee to kick start your day. You should try it.
    oldrocker wrote: »
    Yeah...My bad David. I thought you were a tree.
    oldrocker wrote: »
    You got lucky, seen him try to hump a leg or two after midnight
    edited July 2018
    txcoastal1 wrote: »
    oldrocker wrote: »
    .....and not necessarily human legs either. ;):p
    Just ask Ryan, ya share a room with Russ and you better bolt 2 sheets of plywood around your bottom half before going to sleep. Even then, you might be woken up at 3 a.m. by the sound of a drill with a hole saw. :)
    For those that need a visual ……..
    lightman1 wrote: »
    But he'd pay you well to do it for him...
