"I'm on the Mexican radio...oh...oh"...or....
trubluluc
trubluluc Posts: 2,067
edited December 2004 in Speakers
....should I say the mexican radio is on me.
I have a pair of RT3000 mains which for some reason are picking up a mexican radio station.
I have them plugged into a Monster HTS 2000 surge protector that I thought would remove any RF signals,
but you can hear it pretty clear when the subs are on but no audio signal,
(when everything else is off as in right after watching a movie).
Any suggestions?
I mean, other than learning spanish
-Luc
Post edited by trubluluc on
  • steveinaz
    steveinaz Posts: 19,545
    edited November 2004
    Do you have a receiver or seperates? Sometimes receivers will "bleed" fm signals.
  • hoosier21
    hoosier21 Posts: 4,418
    wouldn't it only bleed if he had that station tuned in?
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • trubluluc
    ... but it is only really noticeable when everything, receiver included, is turned off.
    Seems like the sub amps are picking this up from somewhere. Because there is nothing coming out of the non powered speakers atop the subs.
    I have a dedicated 20amp breaker to the theater, and I never noticed anything when I was running the RT1000's
    -Luc
  • dorokusai
    dorokusai Posts: 25,576
    Unplug your cable company coaxial from the MC 2000 and see if that problem goes away.
  • PolkThug
    PolkThug Posts: 7,532
    Yeah, what doro said, start removing wires/cables, and isolate when the problem stops.
  • up2youjoe
    up2youjoe Posts: 114
    No Kids Allowed
    cold, heartless, clueless, greedy 'young professional'
  • trubluluc
    I will try all and report back.
    -Jorge
  • danger boy
    danger boy Posts: 15,722
    my old PSW350 sub would sometimes pick up a faint radio station or a CB radio. it stopped after I replaced the subwoofer cable to a sheilded one. no mo radio in my sub.
    PolkFest 2012, who's going>?
  • bknauss
    bknauss Posts: 1,441
    Its a problem with the sub amp. It seems to like to pick up a radio station in some areas. Call up customer service and see if they have any of the upgraded amps lying around.
    Brian Knauss
    ex-Electrical Engineer for Polk
  • ohskigod
    ohskigod Posts: 6,505
    i would go with the sub amp too, only because i remember hearing about that problem a short time ago, just cant remember where.
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • trubluluc
    ....but don't know how to remedy it.
    when the sub amp clicks on it stays on for about 5 minutes even after I shut the main amp off. This of course is normal.
    that is when I hear the radio signal.
    I found the only way to stop the radio signal is to unplug the black speaker wire to the sub amp.
    The main amp I'm using to power the sub does not have a tuner, so no bleeding in of signal. I do not have a cable radio/tv connection.
    I unplugged the speaker leads and used a rca cable from the preout main on the main amp, to the line in on the sub amp. The radio signal is back again.
    I think it must be the sub amp as was suggested by bknauss and ohskigod.
    Any other suggestions, or should I just contact C.S. ?
    -Luc
  • bknauss
    Contact CS! :)
    Brian Knauss
  • trubluluc
    According to Ken, the best remedy is take out the amps and mail them to Polk.
    Is this a straight forward bolt out - bolt in procedure?
    Thanks,
    -Luc
  • dorokusai
    Simple.
  • jdhdiggs
    jdhdiggs Posts: 4,305
    Contact CS but one thing you can try is using a 2-prong extension cord to eliminate the ground line in your power cord. (By only plugging in the two spades and not the prong. If your power cord does not have three prongs, that also could be an issue.
    You have a grounding issue somewhere in the system. Either the power cord or the sub cable. Withe the sub cable unplugged does it happen? Perhaps your recieve isn't grounded causing it and the cable to become an antenna. Lots of stuff to check, just go one step at a time.
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
  • bknauss
    I don't think this is a grounding issue... the amp is just susceptible to other signals. The following wasn't true when the RT3000p's came out, but UL has cracked down on electronic emissions and susceptibility (shooting out RF noise that might be picked up both other electronics or not rejecting RF noise that might be sent out by other electronics). There were some Class T car amps that were having the same problem as the RT3000P's a couple of years ago, except it was much more noticable.
    Brian Knauss
  • trubluluc
    Just an update....
    I emailed Ken and he authorized shipping the amps to POLK San Diego.
    They shipped me the newer updated version 3 amps.
    I just installed them, and I'm grooving.
    These front firing subs kick some serious ****!
    As always, hats off to KEN SWAUGER,
    the man gets the job done right. :):):)
    -Luc
  • dorokusai
    Ken Swauger is a stone cold, pimp daddy.
  • bknauss
    Originally posted by trubluluc
    Just an update....
    -Luc
    Yea, the subs are pretty sick. I wish the LFE channel wasn't a dedicated channel for DVDs or I wouldn't need a sub.
    Brian Knauss
  • trubluluc
    Have you tried hooking up the LFE line into the subs? I also run a dedicated sub as well, but was wondering about the LFE imput.
    -Luc
  • bknauss
    Haven't tried the using the RT3000P subs for the LFE channel since I like them being full range. I'll just put up the money for a sub at a later time.
    Brian Knauss
