WTB Larry's Rings for SDA-CRS
Dr_Wu
Taking a flyer before starting to drill holes for HNs. This is the 2 tweeters, 2 midwoofers model (1984). Thank you!
I believe westmassguy is handling the rings now. Check with him.
I know he had Gimpod's Circuit Boards, but didn't know he had the Larry's Rings.
News to me. Fake news that is -
My bad. Way to early in the morning to be on the puter.
If you're in between ring cycles (Der Ring des Nibelungen - lol - for you opera fans...? crickets...) you might consider buying/using hurricane nuts - if you haven't already. Almost the same result, and always available.2.3TL's - Living Room
CRS+'s (4.1 TL's) - Office
SDA1C's - Famdamly Rm
SDA1C's - Master Bedroom -
Thanks for the reply Mr Hz. No joy to be found on the ring search. I did install hurricane nuts; they worked out very well. Enjoying the sounds!
Cheers! -
I must ask, what exactly do Larry’s rings do to improve the sound?
They are a mechanical lock down for the drivers. Just help tighten everything up. Improved coupling to the cabinet improves bass response and overall clarity. Also facilitates future mods without risk of stripping wood/MDF screw holes.
mlistens03 wrote: »I must ask, what exactly do Larry’s rings do to improve the sound?
Lock the speaker driver tighter to the baffle. Screw holes do not wear out. -
Thanks!
Larry's rings is just a myth, don't listen to these guys, the rings only bring out the dragons from hell..
Sorry for the late post, Dr. Wu, especially if this has been covered elsewhere...
https://www.youtube.com/watch?v=w58E2S315a4
Yes, just like Larry's spikes!
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Larry is a hack....
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12
