Door, meet CD tray
13»
    Viking64 Posts: 7,563
    Clipdat wrote: »
    Or maybe I should just give it away as Karma on here like I do with all my other stuff?
    Maybe it's time for you to get a new nickname?
    https://www.youtube.com/watch?v=JmcA9LIIXWw
  • chumlie
    chumlie Posts: 8,658
    Go old school on it and smack the other side to even it out.
    mhardy6647 Posts: 35,035
    edited July 2018
    technical knowledge?! what's that!?
    There's screws. You gotta screwdriver?
    Actually, in all seriousness, the screws on the cover that need to be removed are
    often marked with an arrow and the ones that shouldn't be removed are marked with an X.
    Security heads on the screws? No probs. You should have a kit like this anyway :)
    https://www.parts-express.com/vtbt5-33-piece-security-bit-set--360-206
    (or a bigger one...)
    chumlie wrote: »
    Classic troubleshooting/repair methodology. Don't give away all of our secrets!
    :p
    edited July 2018
    Viking64 wrote: »
    Hermitism wrote: »
    OMG! I completely forgot to ask yesterday... Where's @nbrowser ?
    In one of dem dare Providences.
    I don't see Moose Jaw on that map.
    Mrs. H has been to Churchill, birding. Twice.
    She's been to Deadhorse, too. Way up there.
    EDIT: oops,
    Deadhorse.
    Is.
    In.
    Alaska.
    It is way up there, though.
    Hermitism wrote: »
    ...I already miss feeling inferior when Ken constantly brought up how fast his computer is computers are. What if I need help getting to an end of a level in Half-Life 2 or Portal? I miss my buddy.
    I'm no mathematician, but... doesn't Half-Life 2 simplify to Life?
    Tony M Posts: 11,624
    Clipdat wrote: »
    Per @Tony M's suggestion, I counted the teeth on the underside of the tray with it open, from the point where the "last" tooth was resting in it's drive gear. It's the same on both sides, 53 teeth. So not a skipped gear/tooth as far as I can tell.
    I think I'm done futzing with it. I'm just going to use it with it's gimpy CD drawer/tray and get on with life. I'm sure with my luck as soon as I get it back in the rack it'll start having issues reading discs and it'll be time to replace the laser! :)
    Thanks for checking for me! I was hoping that was the problem. Sorry it isn't!
    EDIT: oops,
    Deadhorse.
    Is.
    In.
    Alaska.
    Getting lost in or around Deadhorse would be
    A.
    Bad.
    Idea.
    Clipdat Posts: 13,095
    edited July 2018
    I got an email reply from B&W Support, and they informed me that replacement parts for the 1072 are still available: http://www.bwgroupusa.com/bwgroup-parts/index.php/rotel/cd-players/rcd1072.html
    Looks like after tax and shipping, the total for the CD Loader Assembly is $130.
    So, it's nice to know that it's available, but I have to consider the amount of money I want to put into the player.
    From a financial standpoint, it might make more sense to just save that $130 and put it toward the latest object of my desire, a Marantz SA-14S1.
    I think when I land a new job, I'm going to celebrate by getting that 14S1 for myself.
  • BlueFox
    BlueFox Posts: 15,251
    Good luck. I use that logic for buying stuff. I got a bonus. Buy. I got stock options. Buy. :)
