Class H power supply?
CH46E
CH46E Posts: 3,595
edited July 2018 in 2 Channel Audio
Does anyone know if the class H power supply amps are quality? Do the keep up with say a class a/b with troidial power supplies?
I was looking at the emotiva xpa 2 gen 3 and noticed they did away with the troidial transformer.
  • CH46E
    CH46E Posts: 3,595
    edited July 2018
    Looks a little like a class D or is it similar to Carver magnetic field power supply?
    When i see the words "switching power" used to describe class H i think of Class D.
    mhardy6647 Posts: 35,149
    edited July 2018
    Class H was a Soundcraftsmen thing, wasn't it?
    I think it's similar to Hitachi's Class G :p with two different sets of rail voltages(?).
    EDIT:
    source: https://www.hifiengine.com/manual_library/soundcraftsmen/equalizers-preamplifiers-amplifiers.shtml
  • CH46E
    CH46E Posts: 3,595
    Thanks for the links. I did learn something from them. But more so, i was wondering if anyone knew if they were up to par with traditional power supplies.
    I have been watching #jdjohn post about PS Audio's Class D amp. I for one worked at a shop (ListenUp Audio/ Video in Colorado Springs) that had Rotel and was there when Rotel dove into Class D amps. No one at the shop was sold on it and always doubted the power ratings in such a light weight package. That was 2004 or so. I know much has changed since then.
    My question was more " are they at least as good as" troiadal power supply amps?
    I think im going to keep my Parasound 2250 v2 for a sub amp (750x1) on a Dayton Audio Ultimax 15 or other 18 inch sub and buy something else to power the RTA12B mains.
  • CH46E
    CH46E Posts: 3,595
    From what i can tell, none of the gen 3 xpas have a troidial transformer. Looks like class h does not need them. I think the xpa 2 you show in your pic is a gen 1 or 2.
    edited July 2018
    It's not at all clear to me how the Soundscraftmen Class H power supplies were configured. That said, I haven't actually gone to the effort to look at the schematic for one of the amplifiers :p
    My impression was that they used linear power supplies - but I dunno.
    As to the issue of weight & power, the wild card is efficiency. A lot of the reason that such massive linear supplies are (were) required for normal consumer AC equipment with moderate/high power requirements was the choice of 60 Hz as the power line frequency. If the standard were, say, 400 Hz, the size and weight of transformers (and smoothing capacitors or chokes) can be much reduced. US military equipment, at least back in the old days, used 400 Hz AC.
    Switching supplies --I think! -- leverage this property by regenerating higher frequency AC (or pulsed DC), so that any transformers and filtering components can be much smaller.
    "digital" amplifiers are likewise much more efficient than traditional linear amplifiers -- although it's worth noting that an amplifier operating in pure Class B can be quite efficient.
    The "problem" with switch mode power supplies is the high frequency "hash" noise generated by the supply. :(
    There is way more AC/RF noise in our environments now than there was, say, 40 years ago -- the implications for this, of course, are a higher bar for shielding, filtering, and isolation. :p
    heiney9 Posts: 25,486
    edited July 2018
    Just because Emo has a lot of caps and big torrid, doesn't mean they are "on par" with other names bandied about. There is a whole lot more to the PS section in an amp than caps and a torrid.
    I'm not saying they are lacking in and of themselves, but to make the leap they are on par with other well known, well reviewed and well like names is a big leap, especially since the others mentioned are a completely different topology (class A/B vs. Class H or G or D in the Emo's). In general switching type PS (D, G, H topologies) aren't always the best solution, they are a compromise in size, weight and cost. Efficiency and cost reduction is the driver. Certainly adequate.
    Run your mains with your Parasound and leave the sub duties to the Emo. You can thank me later :)
    Post edited by heiney9 on
    Linear P/S with big-rump chokes is where it's at baby.
    If you can lift it, it ain't big enough. ;)
  • CH46E
    CH46E Posts: 3,595
    heiney9 wrote: »
    So i hooked the Parasound back up to my mains (rta12b) and have a new appriciation for its sound and bottom end. I was running them off the Yamaha htr rxa1050 while no slouch its self it just does not compete. Im glad i did not sell the Parasound now.
  • lightman1
    lightman1 Posts: 10,797
  • lightman1
    Shots fired!! We need back up!
    Man Ryan, you'd think Brock came over and took the lightbulb out of your bathroom and left the plunger in the toilet. :)
    edited July 2018
    ZLTFUL wrote: »
    I am not sure what your problem with me is Brock but you seem to always want to piss on any suggestion I make and in fact seem to go out of your way to poo poo on anything I post that isn't in exact alignment with your own opinions.
    And to say I made "a leap" would discount the fact that the following amps were extensively tried before I ended up with the Emotiva XPR...
    Adcom GFA-555
    Adcom GFA-5500
    Adcom GFA-5503
    B&K ST-140
    B&K ST-202
    Parasound HCA1500
    Parasound 2150
    Parasound 5250
    So before you claim I made a "leap" in my assertion, maybe you should have asked a qualifying question like what did I compare them to before dumping all over my opinion like it was somehow wrong on every level.
    I have zero problems with you. Just sayin' it how I feel. I didn't even really look at who wrote what I was commenting on. I was commenting in the thread not to you personally.
    Great, glad it worked for you, we all have our own nirvana we are searching for. My comment was in general, there are certainly exceptions, but in general. That's how I feel and I'm sorry you took it on a personal level. it wasn't meant that way at all.
    We have opposing opinions, no one peed in your Cherrio's, hence I think you are overreacting a tiny bit (again my opinion). My comments weren't made to denigrate you, they were made to the OP. It appears he agrees at this juncture.
    P.S. You never went into any detail in your original post about the process or gear you tried. I am not a mind reader, so to throw that in the argument now as a way to defend against what I said is kind of silly.
    edited July 2018
    I didn't even quote you or mention your name and you're jumping down my throat? Maybe you have a chip on your shoulder and are just looking for an argument? Don't direct your chipped shoulder at me.
    Also my general opinion about Emo gear has been steadfastly consistent over the years so not sure if you were having a bad day or what................but no one was out to bash you.
    Calling something "adequate" hardly equates to bashing.
  • steveinaz
    steveinaz Posts: 19,545
    Soundcraftsmen's were Class H amplifiers and had a tubey sound quality to them; at least in the A5002 and twin PM840's I owned years ago.
    edited July 2018
    I see the chip is well attached. Again, I wasn't trying to attack you personally in any way. When I responded I was responding to the text in the post not the person behind the post. When you first posted your displeasure, I was like What?. I had to go back a re-read the thread to figure out why you were so vitriolic.
    I would have responded exactly the same to any one who stated what you did. No intention of singling you out.
    That's all I'm saying in this thread. You analyze it, and come up with your own conclusion, as you seem to think I somehow dumped on you. I know now you're saying your post, before I was supposedly attacking you personally.
    I didn't and I'm not. Nor did I ever intend in the past to single you or your posts out on purpose. End of story
    nooshinjohn Posts: 25,955
    Emotiva is a choice to be made when considering new vs. used gear IMHO, but it is not on the same level as new Parasound, Bryston, etc...
    Emotiva started life by rebadging a Carver Digital(Phoenix Gold) class H 5 channel HT amp, and much of their tech comes from that amp and from taking bits and pieces from other designs. Not saying at all that they are not a good amp for what they offer, but Parasound they are not.
  • CH46E
    CH46E Posts: 3,595
    Just so everyone knows, i only brought up the Emotiva because its the first time ive seen a class h power supply. As i was looking at the emotiva amps i noticed some were missing the huge transformer.
    Am i correct to say that it is still a class ab amp? Just a different power supply right? If so, i was only wondering if the class h power supply had any benifits like a lower noise floor or if the bass was as punchy ect.
    edited July 2018
    A well designed standard power section will be better than most class H offerings. Class H is for economy of size and cost savings. Less parts, less weight, more cost effective parts = economy. It's a compromise vs. a well designed power supply section. Audio is full of compromises. Class A/B is compromise vs. Class A, doesn't mean A/B sounds poor, etc.
    Not judging good or bad just relating why it's used.
    That's not to say there aren't some economy standard PS sections in gear. It goes both ways to a point. When care is taken and cost is not spared, a standard PS section is better than Class H switching supply's. The downside is heft and cost of the former.
    I wouldn't mind having an MPS-1
    edited July 2018
    It's kind of a variable rail class AB amplifier topology, somewhat more sophisticated/subtle than Hitachi's "Class G". The amplifier is considered "Class H" (a moniker which was invented, AFAIK, by Soundcraftsmen). The power supply design enables the "Class H" operation.
    "Class G" had a power supply with two rails and could "instantaneously" switch to the higher rail to give a little added headroom when needed. "Class H" kind of lets the rail voltage slide on up when required, in "real time".
    I put "instantly" and "real time" in quotes because... yeah... marketing :)
    I wouldn't say that the Soundcraftsmen amps sounded "tubey" at all -- my recollection of them is that they were kinda brittle sounding... like they were workin' hard at doing their jobs. It's been decades since I heard one, though.
  • CH46E
    CH46E Posts: 3,595
    edited July 2018
    ZLTFUL, what gen XPA do you have? I ask because i think all the gen 1 and gen 2 are regular troidal power supplies. I think only the gen 3 gear use the Class H power supply and therefore would NOT need have a troidal PS. Also i think if it weighs 100+ lbs than you have that massive troidal transformer and therfore would be a class AB PS.
    Or am i totally wrong???
  • CH46E
    CH46E Posts: 3,595
    In this pic i see the power wires (in red) lead strait to a board and not a transformer. bxerlixi55rq.png
  • CH46E
    CH46E Posts: 3,595
    Oh wow, thanks for that. I was clearly mis informed.
