Recommends Me a Blu Ray Playa
kevhed72
kevhed72 Posts: 5,146
Something new and not too high end, since this will be for our 2nd TV. Alot of the Samsung and LG ones look way cheap...perhaps a Sony or Yamaha?
Really looking to spend under 200 and dont need 3d or 4k....thanks
    gudnoyez Posts: 8,165
    Sony UBP 800, but if you don't need 4k or 3D then just about any one you kind find at Walmart or best buy should do the trick, I would probably just get one of the cheaper Sonys and be done with it.
  • kevhed72
    Ill open up ideas to used Pioneer and other decent players....
    edited July 2018
    https://www.sony.com/electronics/blu-ray-disc-players/ubp-x800
    Up your budget 50 bucks and get one of these you don't have to use the 4K and 3D options but will be available should you change your mind. I have seen these on E-Bay for $150, pretty versatile player for not much coin. I have been using mine more than my Oppo player latley.
  • motorhead43026
    motorhead43026 Posts: 4,012
    I am on the Oppo list for a 203. If I fail to get one this Sony mentioned above will be my default.
    – Kevin Alfred Strom
  • kevhed72
    I just realized our TCL P series TV is 4k capable. I have not seen any 4k content yet so that Sony may be the ticket.
    pitdogg2 Posts: 27,064
    kevhed72 wrote: »
    Do it...
  • mrloren
    mrloren Posts: 2,474
    Get a Sony,
    I've owned or still have Samsung, Panasonic, LG and some off brand stuff. In the end it's always a fallback to Sony.
    Oppo and Pioneer Elite are better but out of your price range.
  • Airplay355
    Airplay355 Posts: 4,298
    TheUBP X700 is right at your budget. It's the same as the 800 except with a cheaper case, power brick, and smaller. It can do Dolby Vision where the x800 can't. The X800 looks like it's built better and is standard component size but it's a little more expensive. I went with the X700 and I have no complaints. It loads discs quickly and doesn't skip. My only complaint is it's a little noisy but I have it in a cabinet now and since it doesn't generate any heat (power brick outside cabinet), it can make all the noise it wants in there.
    https://www.amazon.com/Sony-UBP-X700-Ultra-Blu-ray-Player/dp/B078HXF9H2/ref=sr_1_5?s=electronics&ie=UTF8&qid=1531082093&sr=1-5&keywords=sony+ubp-x800
  • Check online and search the price under 200, you will found a lot.
  • Mr_Hz
    Mr_Hz Posts: 176
    I already have a modded Oppo UDP-105D + high end Pioneer Plasma, and have been slow (ok, non-action) to adopt 4k. But when I do... that Sony UBP-X800 looks like a reasonably priced option for 4K.
    2.3TL's - Living Room
    CRS+'s (4.1 TL's) - Office
    SDA1C's - Famdamly Rm
    SDA1C's - Master Bedroom
