How do I best clean the midbass? It has lint on it. How do I best clean/restore the rubber
RTA 11T
jr5
SDA SRS2
Answers
  • motorhead43026
    motorhead43026 Posts: 4,031
    Windex with ammonia.
    – Kevin Alfred Strom
    F1nut Posts: 52,008
    Original Windex sprayed onto a soft, lint free cloth. Never spray the drivers directly. Use a circular wiping motion with light pressure. Be sure to clean the rubber surrounds at the same time. You'll find a lot of brown stains on your cloth at first from cleaning the surrounds. Clean the PR's too.
  • tonyp063
    tonyp063 Posts: 1,137
    Also be aware that the mid-woofers, even when clean, have a certain amount of tackiness on the cone.
    This is normal. Don't go overboard & try to clean it off.
