Save an M0.5t?
Airplay355
Airplay355 Posts: 4,298
An old carver M0.5t amp needs a refresh/fixing. The cost is around $400. I was interested in an amp for the SDA 2b I have. Is this amp worth rescuing or is $400 better spent on a different amp?
  • daddyjt
    daddyjt Posts: 3,129
    edited June 2018
    Someone is trying to rob you - A recap and calibration on that amp is $100 job tops, plus shipping. Unless the transformer is bad, a likely repair should be <$25. That said, I would want a bit more amp behind those speakers.
    ― Aleksandr Solzhenitsyn
  • rooftop59
    rooftop59 Posts: 8,120
    edited June 2018
    Lots of REALLY solid amps can be had used for $400. Heck, with patience you could pick up marantz or outlaw mono blocks. Or a Parasound hca 1200 or possible even 1500, lots of good rotel and b&k amps etc. I would sell it for parts and move on...
    Game Room 5.1.4:
    Bedroom 2.1
    Ditto ^^^^^^^^^
  • steveinaz
    steveinaz Posts: 19,546
    Ditto/Ditto ^^^^
    pitdogg2 Posts: 27,244
    rooftop59 wrote: »
    Of course the mono bloc's would present another problem with these speakers...
    Nice amp ^^^, go grab it.
  • Airplay355
    Alright to the parts bin it goes :)
    I need to do some closer cleaning out. It’s getting filled up with unwanted audio bits.
  • Airplay355
    Anyone want it? Haha
