Want to enhance current home theater setup
sullyscrib
sullyscrib Posts: 1
edited December 2004 in Speakers
Currently have the Polk RM7500 and a PSW650 sub. I am looking for some feedback on these speakers as well as a way to improve it. The receiver is a Yamaha HTR5250. It just isn't sounding right when playing music, tends to lose midrange.
Any suggestions/comments?
Post edited by sullyscrib on
  • Joey_V
    Joey_V Posts: 8,600
    Perhaps you need to get speakers just for 2 channel?
    Lsi are musical as can be!
  • Willow
    Willow Posts: 11,233
    Right you should buy yourself a pair of bookshelves and use the B of your receiver for music
  • steveinaz
    steveinaz Posts: 19,545
    You may need to back-off on the sub a little when listening to music. Subs sound really cool on movies, but can muddy things up on music.
  • Willow
    very true right on when you are running sats as they do not have as big midrange therefore the sub is needed to fill in those gaps
  • Joey_V
    Joey_V Posts: 8,600
    Ah yes, calibrate the sub to match with your system better. The sub should integrate with the system and not stick out like a sore thumb.
    Go to radioshack and get an spl meter. Use the spl meter in conjunction with your receiver's tones or an avia disk (or pretty much anything with a steady sound output) to calibrate all your speakers including the subwoofer.
