Problem with Yamaha RX-A2070
Milito
Milito Posts: 2,002
I just got my 2070 from accessories for less today and the unit looks great except for one problem. The 5th foot (one in the center) is higher than the rest and it high centers on it.
Anyone else had this kind of problem with the upper RX-A Receivers?
I can't hook it up right now to see if there are any others issues as I'm waiting for our wood floors to be put in. I'm going to call accessories for less to see what can be done about it tomorrow.
  • Milito
    Milito Posts: 2,002
    Thanks for the reply, that was one of the first things I checked. I even took it off to see if it was seated correctly and also checked all of the feet.
  • ken brydson
    ken brydson Posts: 8,981
    edited June 2018
    You could add washers to the corner feet to level it out. Just a thought...
  • Milito
    Milito Posts: 2,002
    I called accessories for less and they told me to call Yamaha. I put some add on rubber pads on it last night to even it out so I'll probably just do that even though I'm a little upset the center foot is so far off compared to the other feet.
  • jeremymarcinko
    jeremymarcinko Posts: 3,785
    So weird. Does the corner feet have the felt pads under them? I’m pretty sure mine does at the corners.
  • Milito
    Milito Posts: 2,002
    Yes
