Any need for "Broken" Rd0194s?
codycatalist
codycatalist Posts: 2,661
edited June 2018 in Vintage Speakers
I have 3 Rd0194s that I believe got damaged in my move (although they were in the boxes Polk sent), the tabs are a little loose on the positive side. They play but have resonance on certain piano notes and frequencies.
I don't have the technical capacity to try and fix, not sure if anyone else has any use for them or wants to take a crack at fixing. Ill have to see how much shipping is, maybe able to cover it if under $20.
  • FestYboy
    FestYboy Posts: 3,861
    hmm, smell a challenge :*
  • codycatalist
    FestYboy wrote: »
    I might not be remembering correctly but didn't you make a post about replacing the tweeter diaphragm for the SL2000s?
    Either way if you want em you can PM me your addy and I can see how much shipping would be. I don't assume it will be too expensive so I can send em free of charge. = ]
  • codycatalist
    la2vegas wrote: »
    If @FestYboy passes let me know.
    Will do!
  • FestYboy
    edited June 2018
  • FestYboy
    Grrrr can't get image to post correctly.... Brb.
  • codycatalist
    Hahaha nice. PM me your addy and I'll see if I cant get them out by the end of the month.
  • FestYboy
  • FestYboy
    Gotta see if I can get the "comment" deleted....
