Garage/Workbench Rig
Been working on having more functional garage storage and workbench space in my spare time. I had a couple of pairs of Atrium SAT30's that I picked up and decided to mount a pair on my workbench. I'd like to find an integrated with Blutooth without spending too much that will be ok in the heat and humidity of a Florida garage... 50 wpc should be fine. Anybody have any suggestions?
Garage | Polk Monitor 5B's
  • Mikey081057
    Mikey081057 Posts: 7,127
  • Mikey081057
    msg Posts: 10,452
    Pretty cool, Mikey.
    I ended up pulling together a little system for my garage, too, using a Squeezebox and a set of old Boston Acoustic 2.1 computer speakers I got with my first computer back in the 90s, a Gateway PII-233Mhz :D
    The surround disintegrated on the little 4" sub driver, but I was able to replace it with one from Parts Express. Works pretty nicely out there, and makes for some nice atmosphere when I'm doing stuff. The idea was so that I'd have one less excuse for when I had to do stuff I didn't really feel like doing. Fun project, and provides a little "comp'ny".
  • erniejade
    erniejade Posts: 6,321
    https://soundboks.com/?noredirect=true
    Soundboks 2. Water smash element proof.
  • rburgess714
    rburgess714 Posts: 618
    I got that unit for the GF and some used S15s and she loves it. Now I don’t have to listen to her little portable Bluetooth speaker. Great little rig.
    Living Room
    Parasound HINT 6, Yamaha Aventage RX-A 1060, Oppo 103D, Cambridge Audio Azur 851N, KLH Model 5s, Polk CSi A6, Samsung 65" LED
    Office
    Yamaha A-S501, Auralic Aries Mini, LSiM 703s
    Douglas Connection ICs and Cables
  • Mikey081057
    I figured I would just throw a cover on it when not in use...
  • Mikey081057
    So I got the Yammy and plugged it all in.... I didn't like the sound of the SAT30's so I ditched them and put my old standby 5B's in place.
    At least they have some growl to them
  • Conradicles
    Conradicles Posts: 6,339
    Now that's more like it!
    Clipdat Posts: 13,095
    Nice tight grouping there! ;)
    msg Posts: 10,452
    Heck yeah, Mikey!
    Now you just need a second work bench to work on, so that one doesn't get messed up B)
    Love those M5s...
    Do you have a liddle sub in the mix yet?
    (You will. This ain't over yet, friend. I found unexpectedly that little systems that initially aren't intended to be serious end up being really fun to play with and build out. Next stop, Sound Addicted Acoustic Foam Iso Pads. Amazon 'em tonight so you'll have them by Tuesday)
  • Mikey081057
    msg wrote: »
    Heck yeah, Mikey!
    Love those M5s...
    There are actually 2 more workbenches to the left of that .... yes a sub is in the works
  • mlistens03
    mlistens03 Posts: 2,767
    Nice setup, enjoy it!
    What kind of stuff do you work on there?
  • Mikey081057
    Try to avoid work whenever possible...Just typical household maintenance stuff...
